sumo
Bike 2016 NC750X DCT ABS
I bought this Triple Tree Stand for $75. Five pins came with it 18 17 16.5 15 13 (all measures mm) I assume that the fit should be quite snug. There is not much difference between 18 and 17, even less between 16.5 and 17
The biggest is 18 and is a super sloppy fit, I measured and figure 23 would be a snug fit. Furthermore, in the area is a block that the front brake line and ABS sensor wire are connected to and is right in the way even if they gave me a 23. To make it work I would need to extend the length of the pin such as shown the 48 mm extension would allow the lift to clear the brake hose block.
So much of this sport is 'making it fit' and I do enjoy a challenge however should I pursue this or just return the stand for a store credit (no refunds).
I don't have access to a lathe.
