WingMan71
Loving my new-to-me 2018, and have already fixed my windshield and bar reach problem. The Madstad windshield fixed the wind problem and the bar risers fixed the reach problem.
But, I'm short with a 30" inseam, so on to my next problem...
I'm almost flat-footed at stops with my riding boots on, but not quite. So, I'm trying to get the bike as low as I can without resorting to buying and replacing parts.
Today I adjusted the rear shock to it's "lowest' setting, meaning the shock is extended to its maximum allowable length by moving the adjusting rings. There are about 1.125" (2.86 cm) of adjusting threads on the stock rear shock. Mine was set at the mid-way position when I bought the bike. I was able to move the adjusting rings toward the top of the existing threads with the shock on the bike! "How", you ask. Well... with a 20" long screwdriver and an impact hammer. I loosened the locking ring from the left side, moved the rings up, then tightened the locking ring back up from the right side. Pretty easily done actually. I moved the rings up a good 1/2 inch (1.27 cm).
Here is their final position after the adjustment. (Yes, I was able to align the yellow index marks when finished so I can tell if the rings are staying put.)
![20240531_165925.jpg 20240531_165925.jpg](https://www.nc700-forum.com/data/attachments/45/45593-bdaa23020bc9875f12525569261e11b4.jpg)
So, my question is:
"CAN'T I NOW MOVE THE FORKS UP IN THE TRIPLE TREE THE SAME AMOUNT TO BRING THE FRONT END DOWN TO MATCH?"
What say you?
So, my question is:
What say you?
