2021 BMW F 850 GS [Model Overview]
The 2021 BMW F 850 GS Can Conquer Any Terrain​
The BMW F 850 GS is an ideal adventure motorcycle. It’s smaller and more agile than the larger GS models, but it doesn’t compromise on power and performance. It has the perfect balance of off-road agility and on-road performance, and that’s why it’s one of the most exciting motorcycles in the 2021 BMW line-up.
The F 850 GS draws power from a European-made liquid-cooled parallel-twin engine. This 853 cc twin-cylinder powerplant produces an impressive 90 horsepower and 63 lb-ft of torque, delivering power across the rev range. This makes it ideal for rugged off-road riding, high-performance road riding, and economic commuting too.
To match the impressive engine performance, BMW Motorrad has added a number of exciting riding aids and standard features to the F 859 GS. Rider aids include ABS, Automatic Stability Control, and selectable riding modes (Rain and Road), controlled via an on-board computer. Practical touring accessories include adjustable levers, LED lighting, and a tough engine guard.
For 2021, the F 850 GS is available in three color options: Racing Red, Rallye Blue Metallic, or a special edition black and yellow design that celebrates 40 years of the GS brand designation.
The 2021 BMW F 850 GS starts at $13,545 USD / $15,100 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 BMW F 850 GS in one place.
2021 BMW F 850 GS
  • Price: $13,545 USD / $15,100 CAD
    • ABS Pro and DTC as standard
    • Dynamic ESA Pro
    • Adjustable windshield
  • Engine: 895 cc water-cooled in-line two-cylinder engine
  • Power: 90 HP
  • Torque: 63 lbs-ft
  • Wet Weight: 504 lbs (229 kg)
  • Seat Height: 33.9 in (860 mm)
2021 BMW F 850 GS
2021 BMW F 850 GS Specifications​
ENGINE
Engine853 cc, Liquid cooled, 4-stroke parallel twin engine
Engine Power90 Hp
Bore x Stroke84 mm x 77 mm
Compression Ratio12.7 : 1
Mixture controlElectronic fuel injection
Max Torque63 lb-ft (86 Nm) at 6,250 rpm
DRIVETRAIN
ClutchMultiple-disc wet clutch (anti hopping), mechanically operated
TransmissionConstant mesh 6-speed gearbox integrated in crankcase
DriveChain Drive
CHASSIS
Suspension FrontUpside-down telescopic fork, Ø 43 mm
Suspension RearCast aluminium dual swing arm, central spring strut, spring pre-load hydraulically adjustable, rebound damping adjustable
Brakes FrontDual floating disc brakes, dual-piston floating calipers, diameter 12.0″ (305 mm)
Brakes RearSingle disc brake, diameter 10.4″ (265 mm), single-piston floating caliper
Tires Front90/90 – 21 54V
Tires Rear150/70 – 17 69V
Fuel Tank Capacity4.0 gal (15 l)
ColorRacing red
ELECTRICAL
AlternatorThree-phase 416 W generator
Battery12 V / 10 Ah, maintenance free
HeadlightFull-LED headlight
Tail Light
DIMENSIONS
Overall Length90.8″ (2,305 mm)
Overall Width36.3″ (922 mm)
Overall Height53.4″ (1,356 mm)
Wheelbase62.7″ (1593 mm)
Castor4.9″ (126 mm)
Seat HeightRallye Seat: 35.0″, Comfort Seat: 34.4″, Standard Seat: 33.9″, Low Seat: 32.9″, Low Suspension Kit: 32.1″
Unladen weight, road ready, fully fueled
504 lbs (229 kg)
WARRANTY
Warranty
2021 BMW F 850 GS
2021 BMW F 850 GS Features​
Ride in your mode
The riding modes influence the throttle response and response characteristics of your F 850 GS. At the push of a button, the “Rain” and “Road” modes are ready for a wet or dry ride. The “Dynamic” mode gets the most out of your bike when you really want to accelerate on asphalt, while “Enduro” mode lets you conquer the gravel tracks of the world.
Let yourself be swept away
Curiosity and a thirst for adventure are just the start. The 2-cylinder in-line engine with 90 hp supports you in your riding endeavors, especially with its high torque. It operates economically and delivers impressive performance on a variety of roads or terrain.
2021 BMW F 850 GS Photos​
2021 BMW F 850 GS
2021 BMW F 850 GS
2021 BMW F 850 GS
2021 BMW F 850 GS
2021 BMW F 850 GS Videos
BMW Official Websites
The post 2021 BMW F 850 GS [Model Overview] appeared first on webBikeWorld.
