The 2021 Harley Davidson Freewheeler: Raw Attitude
If two wheels are good then three must be better right? The inherent stability of the 2 rear 1 front format, the Freewheeler is a popular choice for those wanting to stay with an American-made Trike.
One of 3 in the 2021 Harley Davidson lineup, the Freewheeler packs The Milwaukee-Eight® 114 engine pounds and its 118 lbs-ft of torque. Setup for owners to customize, Harley Davidson smartly provides gear such as Reflex
3 Color choices for the 2021 Harley Davidson Freewheeler: Vivid Black, Billiard Teal, and Snake Venom.
The 2021 Harley Davidson Freewheeler starts at $27,999 USD / $34,295 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Harley Davidson Freewheeler in one place.
- Price: $27,999 USD / $34,295 CAD
- Milwaukee-Eight® 114 V-Twin engine
- Brembo ABS Brakes
- 12” Mini Apes
- Optional RDRS
- Engine: 114 ci V-twin
- Power: 100.5 HP (estimated)
- Torque: 118 lbs-ft @ 3000 RPM
- Wet Weight: 1,118 lb. (507 kg)
- Seat Height: 26.2 in. (665 mm)
- Can-Am Spyder F3
- Polaris Slingshot
- Ural Gear Up
2021 Harley Davidson Freewheeler Specifications
Engine | Milwaukee-Eight® 114 V-Twin engine |
Engine Torque | 118 lbs-ft @ 3000 RPM |
Bore x Stroke | 4.016 in. in x 4.5 in |
Compression Ratio | 10..5:1 |
Fuel System | Electronic Sequential Port Fuel Injection (ESPFI) |
Exhaust | Shorty slash down-style chrome finish mufflers |
Clutch | |
Transmission | 6-speed |
Primary Drive | Chain, 34/46 ratio |
Wheels, Front Type | Enforcer Cast Aluminum |
Wheels, Rear Type | Enforcer Cast Aluminum |
Brakes Front | 32mm 4 piston fixed |
Brakes Rear | floating 36mm piston integrated park brake |
Tires Front | MT 130/60B19 M/C 61H |
Tires Rear | P205/65R15 |
Fuel Tank Capacity | 6 gal. |
Color | Vivid Black, Billiard Teal, and Snake Venom |
Ignition | |
Headlight | High beam |
Tail Light | LED |
Overall Length | 103 in. |
Trail | 3.96 in. |
Rake | 26 |
Wheelbase | 65.7 in |
Ground Clearance | 4.9 in. |
Seat Height | 26.2 in. |
Weight, As Shipped | 1,085 lb. |
Warranty | |
Extension |
2021 Harley Davidson Freewheeler Features
Milwaukee-Eight® 114 Engine
The most displacement in standard H-D® Touring models. You get 114 cubic inches of passing and horizon-chasing power.Reflex
Linked Brembo® Brakes with Standard ABS
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations.High Performance Suspension
Premium Harley-Davidson touring suspension technology is calibrated specifically for Trike models, delivering a smooth and responsive ride.Mini-Ape Hanger Bars
The 12-inch Mini-Ape hanger bars on the Freewheeler® model are the tallest rise you can get from an OE manufacturer. They pull the hand controls back toward the rider, and reduce the force it takes to turn the front wheel for easy riding and easy handling.Bobtail Rear Fenders
The pair of Harley-Davidson® bobtail rear fenders give the bike classic cruiser lines and styling details.Chrome Slash Cut Mufflers
The Milwaukee-Eight® 114 engine puts its exhaust note out to the world through these chrome slash down pipes.Enforcer Cast Aluminum Wheels
There’s an Enforcer front wheel leading the way, and you’ve got two more to match in the back. Up front, the brake rotors have been redesigned to show off more of the premium custom look of the wheels.7-Piece Nacelle
A classic style chrome headlight nacelle is tucked tight against the frame and forks for a tighter, smaller look. It also accommodates a clean-looking windshield mounting system.Steering Head and Front Forks
The responsiveness is dialed in with a stiff front end and 49mm front forks, plus a steering damper that controls feedback from the road.2021 Harley Davidson Freewheeler Photos
MY21 Photography. FLRT.
MY21 360 Web
2021 Harley Davidson Freewheeler Videos
Harley-Davidson Official Websites
The post 2021 Harley Davidson Freewheeler [Model Overview] appeared first on webBikeWorld.
