2021 Kawasaki KX 230 ABS [Model Overview]
The 2021 Kawasaki KLX 230 ABS: A Subtle, Competent Dual-Sport​
The 2021 KLX 230 ABS is designed by Kawasaki to be a trail bike with number plates. Unlike it’s bigger brother the KLX 300, the 230 is much more at home on the trail than the road. However, that’s not to say it doesn’t have road manners. Powered by a 233cc fuel-injected, air-cooled four stroke single, it packs 20 HP and 11 lb-ft of torque.
The Japanese company doesn’t skimp out on features either. For the first time on the KLX 230 platform, dual-zone ABS comes as standard, compared to separate ABS zones on the 2020 bike. What this means is that the ABS sensor determines the braking load across both wheels at the same time, instead of just on one wheel. An electric starter, indicators, headlight, and fully digital backlit dash complete the dual-sport package.
The 2021 Kawasaki KLX 230 ABS starts at $4,899 USD / $5,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki KX 230 ABS in one place.
  • Price: $4,899 USD / $5,499 CAD
    • Six speed manual transmission
    • Dual-zone ABS standard
    • Electric starter
Main Specs​
  • Engine Type: 233cc, air-cooled, 4-stroke, SOHC 2-valve single
  • Horsepower: Approx 20 HP
  • Torque: 11 lb-ft
  • Wet Weight: 293 lbs (133 kg)
  • Seat Height: 34.8 inches (885 mm)
Competitors​
  • Yamaha XT250
  • Suzuki DR200S
  • KTM 390 Adventure
2021 Kawasaki KX 230 ABS Specifications​
Engine233cc, air-cooled, 4-stroke, SOHC 2-valve single
PowerApprox 20 HP
Bore x Stroke67.0 x 66.0mm
Compression Ratio
9.4:1
Fuel SystemDFI® with 32mm Keihin throttle body
Lubrication
ClutchWet multi-disc manual clutch
Transmission6-speed, return shift
Final DriveChain
Suspension Front37mm telescopic fork/9.8 in
Suspension RearUni-Trak® linkage system and single shock with adjustable spring preload/8.8 in
Brakes FrontSingle 265mm petal disc with a dual-piston caliper with Dual Purpose ABS
Brakes Rear
Single 220mm petal disc with single-piston caliper with Dual Purpose ABS
Tires Front2.75 x 21
Tires Rear4.10 x 18
Fuel Tank Capacity2.0 gal.
Color
Lime Green
IgnitionTCBI Electronic Advance
HeadlightLED
Overall Length82.9 in.
Overall Width32.9 in.
Overall Height45.9 in.
Wheelbase54.3 in.
Ground Clearance10.4 in.
Seat Height34.8 in.
Curb Weight293.3 lb. / 295.5 lb. CA model
Warranty6 Months
2021 Kawasaki KX 230 ABS Features​
ABS (Anti-lock Brake System)​
2021 Kawasaki KX 230 ABS Photos​
2021 Kawasaki KX 230 ABS Videos​
N/A
Kawasaki Official Websites​
The post 2021 Kawasaki KX 230 ABS [Model Overview] appeared first on webBikeWorld.
