2022 BMW F750GS [Specs, Features, Photos]
The 2022 BMW F750GS: Not To Be Overlooked​
There is little doubt BMW Motorrad can occasionally be confusing. The F750GS is part of the Adventure family, and it seemingly shares an inline 2-cylinder engine with the F850GS, albeit with a horsepower output tuned to 77 hp. This is a European Adventure bike that like adventures on the pavement, and in that environment, it becomes a very competent middleweight touring machine.
Well equipped in standard form the F750GS has the 6.5″ full-color TFT display with connectivity, Traction Control, BMW Motorrad ABS Pro, and Rain / Road ride modes. As with most of the 2022 BMW lineup, there are very compelling choices on the options sheet. Stepping up to the premium package will add the Dynamic ESA electronic suspension and goodies like Ride Modes Pro.
For those with a smaller inseam, the F750GS could be an excellent choice. Multiple seating choices are available, and finding a comfortable riding position is easier than on the taller siblings.
3 Color choices for the 2022 BMW F750GS: Light White, Sport, Triple Black
The 2022 BMW F750GS starts at $9,995 USD / $11,475 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 BMW F750GS in one place.
2022 BMW F750GS
  • Price: $9,995 USD / $11,475 CAD
    • BMW Motorrad ABS Pro
    • DTC (Dynamic Traction Control)
    • Selectable Ride Modes Rain / Road
    • LED headlight
    • LED indicators
    • 12 V power outlet and USB charging socket
    • Adjustable handbrake lever and clutch lever
    • Connectivity incl. 6.5″ full color TFT display
Main Specs​
  • Engine: 853cc Parallel Twin
  • Power: 77 hp (57 kW) at 7,500 rpm
  • Torque: 61 lb-ft (83 Nm) at 6,000 rpm
  • Wet Weight: 493 lbs. (227 kg)
  • Seat Height: 32.1″ (815 mm)
Competitors​
2022 BMW F750GS
2022 BMW F750GS Specifications​
Engine853cc, Water-cooled 4-stroke in-line two-cylinder engine, four valves per cylinder, two overhead camshafts, dry sump lubrication
Engine Power77 hp at 7,500 rpm;
Bore x Stroke84 mm x 77 mm
Compression Ratio12.7 : 1
Fuel deliveryElectronic fuel injection
Max Torque61 lb-ft at 6,000 rpm
ClutchMultiple-disc wet clutch (anti hopping), mechanically operated
TransmissionConstant mesh 6-speed gearbox integrated in crankcase
DriveChain Drive
Suspension FrontTelescopic fork, Ø 41 mm
Suspension RearCast aluminum dual swing arm, central spring strut, spring pre-load hydraulically adjustable, rebound damping adjustable
Brakes FrontDual disc brake, floating brake discs, 12.0″ (305 mm), double-piston floating caliper
Brakes RearSingle disc brake, 10.4″ (265 mm), single-piston floating caliper
Tires Front110/80 R19
Tires Rear150/70 R17
Fuel Tank Capacity4.0 gal. (15 l)
Color Sport, Light White, Triple Black
AlternatorPermanent magnet generator 416 W (nominal power)
Battery12 V / 10 Ah
Headlight
Tail LightLED Tail Light
Overall Length88.8” (2,255 mm)
Overall Width36.3” (922 mm)
Overall Height48.2” (1,225 mm)
Wheelbase61.4” (1,559 mm)
Castor4.1” (104.5 mm)
Seat HeightComfort Seat: 32.7″, Standard Seat: 32.1″, Low Seat: 31.1″, Suspension Lowering Kit: 30.3
Unladen weight, road ready, fully fueled
493 lbs. (227 kg)
Warranty
2022 BMW F750GS
2022 BMW F750GS Features​
Dynamic ESA​
Dynamic ESA adapts the suspension of the chassis automatically to the conditions: for improved contact between the tires and the ground.
ABS Pro and DTC in series​
ABS Pro allows the rider to keep control over the machine during braking round curves. Dynamic Traction Control (DTC) prevents the rear wheel from spinning during changing grip conditions, thus providing added stability.
Distinctive LED indicators in series​
The new LED indicators now offer more visibility when turning off towards your next adventure.
Extended Pro riding modes​
Dynamic Brake Control (DBC) aids braking, where the Engine Braking Control (EBC) prevents the rear wheel from slipping when the accelerator is released or during a downshift.
More power with the USB port​
Located on the right in the cockpit, ensuring that your smartphone remains charged and that you have access to your music and contacts.
Connectivity with TFT display and multi-controller​
Connect your smartphone to the bike via bluetooth and keep an overview of the vehicle information, navigation, calls and media with the 6.5 inch TFT display. You can control all functions intuitively via the multi-controller.
Expanded seat variety​
The new “extra low” seat improves the handling and control of the machine, even for shorter riders.
2022 BMW F750GS Photos​
2022 BMW F750GS 2022 BMW F750GS 2022 BMW F750GS 2022 BMW F750GS
2022 BMW F750GS Videos​
BMW F750GS | Easy Going All-Rounder
2022 BMW F750GS Accessories Added
BMW Official Websites​
The post 2022 BMW F750GS [Specs, Features, Photos] appeared first on webBikeWorld.
