The 2022 Can-Am Spyder F3-S Special Series: A Spyder for Sport Riders
Power cruiser comfort with sport bike specifications? If anyone can do that and put it in a trike, it’s the engineers at Can-Am. Their Can-Am Spyder F3-S Special Series takes the original F3 and soups it up with a Sport Riding mode, better shocks, and a lower center of gravity to keep your butt in the saddle no matter how bumpy the road beneath you gets.
The engine here is the same made-in-Europe 1330cc ACE
It’s not that different from the F3—or from last year’s model, although you do get cruise control now and the instrument panel is a bit wider. If you want a bigger trike designed and tuned for sport riding, this is one of Can-Am’s 2022 models you should definitely look at.
The Can-Am Spyder F3-S Special Series starts at $20,499 USD/$25,699 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Can-Am Spyder F3-S Special Series in one place.
Motorcycle Overview
- Price: $20,499 USD/$25,699 CAD
- Upgraded suspension from standard F3 model
- 7.8” full-color LCD instrument panel with Bluetooth connectivity
- Low center of gravity
- Sport riding mode
- Engine: 1330cc ACE
- Power: 115 hp
- Torque: 96 lb-ft
- Dry Weight: 899 lbs (408 kg)
- Seat Height: 26.6 in (675.6mm)
2022 Can-Am Spyder F3-S Special Series Specifications
Engine | |
Engine displacement | 1330 cc |
Type | Rotax® 1330 ACE |
Bore & stroke | 3.31 x 3.14 in. (84 x 80 mm) |
Power | 115 hp (85.8 kW) @ 7,250 RPM |
Torque | 96 lb-ft. (130.1 Nm) @ 5000 RPM |
Lubrication | |
Drivetrain | |
Transmission | SE6 |
Type | Semi-automatic with reverse function |
Gears | 6-speed |
Chassis | |
Suspension Front | Double A-arms with anti-roll bar |
Suspension Rear | Swing-arm |
Brakes Front | 270 mm discs with Brembo† 4-piston fixed calipers |
Brakes Rear | 270 mm disc, 1-piston floating caliper with integrated parking brake |
Tires Front | MC165/55R15 55H |
Tires Rear | MC225/50R15 76H |
Fuel Tank Capacity | 7.1 gal (27 L) |
Color | |
Safety and Security | |
ABS | Anti-lock Braking System |
Anti-theft system | Digitally Encoded Security System (D.E.S.S. |
HHC | Hill Hold Control |
Dimensions | |
L x W x H | 104 x 58.9 x 43.3 in. (2,642 x 1,497 x 1,099 mm) |
Wheelbase | 67.3 in. (1,709 mm) |
Seat height | 26.6 in. (675 mm) |
Ground clearance | 4.5 in. (115 mm) |
Dry weight | 899 lb (408 kg) |
Curb Weight | Black |
Warranty | |
Warranty | 2-year BRP Limited Warranty with 2-year roadside assistance |
Extension | B.E.S.T. extended service term available from 12 to 36 months. |
2022 Can-Am Spyder F3-S Special Series Features
Features
2 halogen headlamps (55/60W)
Front fenders with integrated LED lights
Black perforated seat
Cruise Control
Mono seat cowl
Passenger seat included but not installed
Gauge Spoiler
2022 Can-Am Spyder F3-S Special Series Photos
2022 Can-Am Spyder F3-S Special Series Videos
2022 Can-Am Spyder F3-S Special Series First Ride Impressions
2022 Can-Am Spyder F3-S Special Series Special Series
Can-Am Websites
The post 2022 Can-Am Spyder F3-S Special Series [Specs, Features, Photos] appeared first on webBikeWorld.
