The 2023 Can-Am Spyder F3-S Special Series: Oh So Special
The Spyder F3-S Special Series series from Can-Am is all about bold muscular styling on three wheels. All models push the performance envelope thanks to the European-made, 115 hp, Rotax® 1330 ACETM in-line 3-cylinder engine.
Can-Am equips the F3-S Special Series with a 6-speed semi-automatic gearbox and double wishbone front suspension featuring high-performance KYB shocks , Brembo brakes, traction and stability controls, plus a hill hold feature.
The Spyder F3-S Special Series, steps up the game for the F3 segment of the 2023 Can-Am lineup. The Special improves the technology package with a color 7.8″ (19.8 cm) wide digital gauge cluster and BRP Connect with vehicle-optimized smartphone apps. The F3-S Special also includes (but is not installed) a pillion seat, so now the option to take a passenger is possible.
2023 Can-Am Spyder F3-S Special Series colors: Monolith Black Satin, Manta Green
The 2023 Can-Am Spyder F3-S Special Series starts at $20,999 USD/$26,299 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Can-Am Spyder F3-S Special Series in one place.
Motorcycle Overview
- Price: $20,999 USD/$26,299 CAD
- Muscular design
- KYB High-Performance Shocks
- Semi-automatic transmission with reverse mode
- 7.8” Display with BRP Connect
- Engine: Rotax® 1330 ACE
- Power: 115 hp (85.8 kW) @ 7250 RPM
- Torque: 96 lb-ft. (130.1 Nm) @ 5000 RPM
- Dry Weight: 899 lb (408 kg)
- Seat Height: 26.6 in. (675 mm)
2023 Can-Am Spyder F3-S Special Series Specifications
Engine | |
Engine displacement | 1330 cc |
Type | Rotax® 1330 ACE |
Bore & stroke | 3.31 x 3.14 in. (84 x 80 mm) |
Power | 115 hp (85.8 kW) @ 7,250 RPM |
Torque | 96 lb-ft. (130.1 Nm) @ 5000 RPM |
Lubrication | |
Drivetrain | |
Transmission | SE6 |
Type | Semi-automatic with reverse function |
Gears | 6-speed |
Chassis | |
Suspension Front | Double A-arms with anti-roll bar |
Suspension Rear | Swing-arm |
Brakes Front | 270 mm discs with Brembo† 4-piston fixed calipers |
Brakes Rear | 270 mm disc, 1-piston floating caliper with integrated parking brake |
Tires Front | MC165/55R15 55H |
Tires Rear | MC225/50R15 76H |
Fuel Tank Capacity | 7.1 gal (27 L) |
Color | |
Safety and Security | |
ABS | Anti-lock Braking System |
Anti-theft system | Digitally Encoded Security System (D.E.S.S. |
HHC | Hill Hold Control |
Dimensions | |
L x W x H | 104 x 58.9 x 43.3 in. (2,642 x 1,497 x 1,099 mm) |
Wheelbase | 67.3 in. (1,709 mm) |
Seat height | 26.6 in. (675 mm) |
Ground clearance | 4.5 in. (115 mm) |
Dry weight | 899 lb (408 kg) |
Curb Weight | Black |
Warranty | |
Warranty | 2-year BRP Limited Warranty with 2-year roadside assistance |
Extension | B.E.S.T. extended service term available from 12 to 36 months. |
2023 Can-Am Spyder F3-S Special Series Features
Features
2 halogen headlamps (55/60W)
Front fenders with integrated LED lights
Black perforated seat
Cruise Control
Mono seat cowl
Passenger seat included but not installed
Gauge Spoiler
2023 Can-Am Spyder F3-S Special Series Photos
2023 Can-Am Spyder F3-S Special Series Videos
Can-Am Spyder F3-S 2023 Special Series Three-Wheel Motorcycle
Ready for a road trip ! 2023 Can Am Spyder F3-S Special Series
Can-Am Websites
The post 2023 Can-Am Spyder F3-S Special Series [Specs, Features, Photos] appeared first on webBikeWorld.
