2022 Harley Davidson Ultra Limited [Specs, Features, Photos]
The 2022 Harley Davidson Ultra Limited: Fully Loaded
If you are a fan of the iconic Harley Davidson Batwing fairing then the Ultra Limited is the bike you want for long-distance touring.
The 2022 Harley Davidson lineup shares the powerful Milwaukee-Eight® 114 engine across a few bikes, and it is the perfect choice for the Ultra Limited. Building plenty of torque (119 lbs-ft), the American V-twin exhaust note provides such a sweet sound, but you can always crank up the 4 speaker Boom!
Box GTS Infotainment System and rock out down the road.
The sleek yet spacious Tour-Pak
luggage carrier with included luggage rack can easily house both rider and passenger helmets along with extra travel essentials. Comfort features like heated grips and cruise control are standard, the Reflex
Defensive Rider System is an option, but let’s face it, you know you are adding those very useful electronic rider aids, they are well worth it. The toughest choice you will face ordering your new Ultra Limited is solid color or two-tone, and more chrome or more blacked-out?
There is an amazing list of 8 color choices for the 2022 Harley Davidson Ultra Limited
  • Vivid Black – Chrome Finish
  • Gauntlet Gray Metallic – Chrome Finish
  • Midnight Crimson / Vivid Black – Chrome Finish
  • Reef Blue / Vivid Black – Chrome Finish
  • Vivid Black – Black Finish
  • Gauntlet Gray Metallic – Black Finish
  • Midnight Crimson / Vivid Black – Black Finish
  • Reef Blue / Vivid Black – Black Finish
Check out the brand links below for the entire list of colors available.
The 2022 Harley Davidson Ultra Limited starts at $29,169 USD / $34,999 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Ultra Limited in one place.
  • Price: $29,169 USD / $34,999 CAD
    • Milwaukee-Eight® 114 V-Twin engine
    • Vented Batwing Fairing
    • Two-Tone Paint Options
    • Optional RDRS Electronics Package
Main Specs​
  • Engine: 114 ci V-twin
  • Power: 100.5 HP (estimated)
  • Torque: 119 lbs-ft @ 3000 RPM
  • Wet Weight: 917 lb. (416 kg)
  • Seat Height: 27.5 in. (699 mm)
Competitors​
2022 Harley Davidson Ultra Limited Specifications​
EngineTwin-Cooled
Engine Torque122 ft-lb
Bore x Stroke4.016 in. x 4.5 in.
Compression Ratio
10.5:1
Starter
Exhaust2-1-2 dual exhaust with tapered mufflers
Clutch
Transmission6-speed
Primary Drive
Gear, 34/46 ratio
Front Fork
49mm Dual Bending Valve
Rear Shocks
Premium standard height hand-adjustable rear suspension
Wheels, Front Type
Slicer II cast aluminum with clear coat
Wheels, Rear Type
Brakes Front
32 mm, Dual floating rotors
Brakes Rear4-piston fixed
Tires Front
BW 130/70B18 63H
Tires Rear
BW 180/55B18 80H
Fuel Tank Capacity6 gal.
ColorVivid Black (Chrome Finish), Gauntlet Gray Metallic (Chrome Finish)
Ignition
HeadlightAll LED headlamp
Length
102.3 in.
Trail
6.7 in.
Rake26
Wheelbase
64 in.
Ground Clearance
5.3 in.
Seat Height
27.5 in.
Weight, As Shipped
880 lb.
Warranty
2022 Harley Davidson Ultra Limited Features​
MILWAUKEE-EIGHT® 114 ENGINE​
The most displacement in standard H-D® Touring models. You get 114 cubic inches of passing and horizon-chasing power.
REFLEX
LINKED BREMBO® BRAKES WITH STANDARD ABS​
Designed to help prevent the wheels from locking under braking to assist the rider in maintaining control when braking in a straight-line. ABS operates independently on front and rear brakes to keep the wheels rolling and help prevent uncontrolled wheel lock in urgent situations.
BOOM!
BOX GTS INFOTAINMENT SYSTEM​
An evolved interface experience that offers a contemporary look, feel and function, with exceptional durability and features designed specifically for motorcycling. Every element is optimized to enhance the rider’s interaction with the bike and connectivity with the world.
ELECTRONIC CRUISE CONTROL​
Set your own speed on the 6-Speed Cruise Drive® Transmission. It provides smooth, quiet shifting and adapts to whatever terrain you’re riding on.
HEATED HANDGRIPS​
Equipped with six settings, so you can easily adjust on the fly for the heat you need.
PREMIUM TOUR-PAK® LUGGAGE CARRIER​
A sleek yet spacious Tour-Pak® luggage carrier with luggage rack that can easily house both rider and passenger helmets along with extra travel essentials.
2022 Harley Davidson Ultra Limited Photos​
2022 Harley Davidson Ultra Limited 2022 Harley Davidson Ultra Limited 2022 Harley Davidson Ultra Limited 2022 Harley Davidson Ultra Limited
2022 Harley Davidson Ultra Limited Videos​
Watch This Before Buying The 2022 Ultra Limited! How Does It Rate 1-10 ?
2022 Harley-davidson Ultra limited Walkaround & Highlight:
The post 2022 Harley Davidson Ultra Limited [Specs, Features, Photos] appeared first on webBikeWorld.
