2022 Kawasaki Ninja ZX-6R [Specs, Features, Photos]
2022 Kawasaki Ninja ZX-6R: From the Street to the Track and Back​
Kawasaki has rarely been content to stay in one lane—and the 2022 Ninja ZX-6R stands as a testament to the brand’s versatility. Seemingly designed with the street and the track equally in mind, the newest model of this bike is a mid-size supersport you’ll have fun riding just about anywhere that’s paved.
The ZX-6R gets its considerable power from a 636cc, liquid-cooled, 4-stroke, DOHC 16-valve in-line four engine, producing 134 hp at 13,500 rpm and 52.3 lb-ft of torque at 11,000 rpm. Rider aides include an assist & slipper clutch, economical riding indicator, Kawasaki Traction Control, multiple power modes, ABS, and more.
For 2022, there have been no major changes to the powertrain, but the Ninja ZX-6R does have Bridgestone Battlax Hypersport S22 tires as standard, and the chassis has been subtly redesigned to make it extra sleek. The gear ratio has also been optimized. The bike comes in the following colours: Metallic Matte Graphenesteel Gray/Metallic Diablo Black, with Lime Green/Ebony/Pearl Blizzard White for the KRT version.
Sport riders would be crazy to ignore this gem while looking through Kawasaki’s 2022 motorcycle lineup. If you’re into japanese motorcycles, track monsters, or both, the 2022 Ninja ZX-6R is a bike you can get excited about swinging a leg over.
The 2022 Kawasaki Ninja ZX-6R starts at $10,499 USD / $13,699 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Kawasaki Ninja ZX-6R in one place.
  • Price: $10,499 USD / $13,699 CAD
    • Kawasaki Intelligent anti-lock Brake System (KIBS)
    • Kawasaki Traction Control (KTRC)
    • Selectable power modes
    • Advanced SHOWA SFF-BP fork
    • Assist & Slipper Clutch
    • Naturally aggressive ergonomics with adjustable clutch lever
    • Multi-function LCD screen
    • Pressed-aluminum perimeter frame
Main Specs​
  • Engine: 636cc, liquid-cooled, 4-stroke, DOHC 16-valve in-line four
  • Power: 134 hp at 13,500 rpm
  • Torque: 52.3 lb-ft of torque at 11,000 rpm
  • Curb Weight: 430 lbs (195 kg)
  • Seat Height: 32.7 in (830 mm)
Competitors​
2022 Kawasaki Ninja ZX-6R Specifications​
Engine636cc, 4-stroke, In-Line Four, DOHC, 16-valve, liquid-cooled
Power134 hp
Bore x Stroke67.0 x 45.1mm
Compression Ratio
12.9:1
Fuel SystemDFI® w/38mm Keihin throttle bodies (4) and oval sub-throttles
Lubrication
Clutch
Transmission6-speed, Manual, Return Shift
Final DriveSealed chain
Suspension Front41mm inverted Showa SFF-BP fork with top-out springs, stepless compression and rebound damping, adjustable spring preload/4.7 in
Suspension RearBottom-link Uni-Trak® with gas-charged shock, stepless compression damping adjustment, 25-way adjustable rebound damping, fully adjustable spring preload/5.9 in
Brakes FrontDual 310mm petal discs with dual radial-mounted, Nissin 4-piston, monobloc calipers
Brakes Rear
Single 220mm petal discs with single-piston caliper
Tires Front120/70 ZR17
Tires Rear180/55 ZR17
Fuel Tank Capacity4.5 gal
Color
IgnitionTCBI w/Digital Advance
HeadlightLED
Overall Length79.7 in.
Overall Width28.0 in
Overall Height43.3 in.
Wheelbase55.1 in.
Ground Clearance5.1 in
Seat Height32.7 in
Curb Weight425.6 lb.*
Warranty12 Months
2022 Kawasaki Ninja ZX-6R Features​
Assist & Slipper Clutch​
Dual Throttle Valves​
Economical Riding Indicator​
Power Modes​
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.
KQS (Kawasaki Quick Shifter)​
Designed to help riders maximize their acceleration on the track by enabling clutchless upshifts with the throttle fully open, KQS detects that the shift lever has been actuated and sends a signal to the ECU to cut ignition so that the next gear can be engaged without having to use the clutch. On models that offer clutchless downshifts, during deceleration the system automatically controls engine speed so that the next lower gear can be selected without operating the clutch.
2022 Kawasaki Ninja ZX-6R Photos​
2022 Kawasaki Ninja ZX-6R 2022 Kawasaki Ninja ZX-6R 2022 Kawasaki Ninja ZX-6R 2022 Kawasaki Ninja ZX-6R
2022 Kawasaki Ninja ZX-6R Videos​
2022 Kawasaki Ninja ZX-6R First Ride | REVIEW
Kawasaki Official Websites​
The post 2022 Kawasaki Ninja ZX-6R [Specs, Features, Photos] appeared first on webBikeWorld.
