2022 MV Agusta Superveloce 800 [Specs, Features, Photos]
The 2022 MV Agusta Superveloce 800 Blends Vintage Racing Legacy With Modern Performance​
The MV Agusta Superveloce 800 is among the most striking motorcycles in the brand’s 2022 catalog and the motorcycle market, specifically in the ‘modern classic’ segment, because of its retro style and impressive performance.
In 2021 this motorbike was improved in several aspects, such as the counter-rotating crankshaft, its DLC (Diamond Like Carbon) treatment, new tappets, and new titanium valve guides.
MV Agusta also redesigned the exhaust, the injectors (0.5 bar more pressure), and the firmware improved the management logic and engine control, thus resulting in a more precise and refined throttle feel. In addition, the dual-flow radiator is new and improves cooling by over 5%.
This Italian-made neo-retro bike features the evolution of the MV EAS 3.0 electronic quick-shift system that is now faster, smoother, and more precise. In addition, the clutch has also been updated with a pressure plate that makes it more manageable and quieter.
The excellence of the chassis of this vintage sports car also improved its architecture with new plates to improve the torsional and longitudinal rigidity of the whole and a more comfortable seat.
Of course, the electronics of the Superveloce 800 are at the forefront with its IMU, which knows the position in space (for example, the inclination) and other data to later manage the rest of the electronic assistance.
The Continental MK100 ABS offers cornering function, traction control, and rear wheel lift-up mitigation.
The 2022 MV Agusta Superveloce 800 starts at $21,245 USD / $27,143 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 MV Agusta Superveloce 800 in one place.
  • Price: $21,245 USD / $27,143 CAD
    • 147 hp 798 cc 3-cylinder engine
    • Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
    • Integrated ignition – injection system MVICS 2.1 (Motor & Vehicle Integrated Control System) with six injectors
    • Marzocchi “UPSIDE DOWN” telescopic hydraulic fork and Progressive Sachs, single shock absorber, both with rebound-compression damping and spring preload external and separate adjustment
Main Specs​
  • Engine: 798 cc, 4-stroke, 3-cylinder, liquid-cooled, 12 valve DOHC
  • Power: 147 hp (108 kW) at 13,000 rpm
  • Torque: 65 lb-ft (88 Nm) at 10,100 rpm
  • Wet Weight: 421 lbs (191 kg)
  • Seat Height: 32.6 in. (830 mm)
Competitors​
2022 MV Agusta Superveloce 800 Specifications​
Engine798 cm3 (48.7 cu. in.), Three cylinders, 4 stroke, 12 valves
Power147 Hp
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio13.3:1
Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappet
ColorPearl Metallic Yellow, Mat metallic Graphite, Black, Ago Red, Ago Silver, Black
ClutchWet, multi-disc slipper clutch
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio17/43
Suspension FrontMarzocchi “UPSIDE DOWN” telescopic hydraulic fork with rebound-compression damping and spring preload external and separate adjustment
Suspension RearProgressive Sachs, single shock absorber with rebound and compression damping and spring preload adjustment
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W) Pirelli Diablo Rosso Corsa II
Tires Rear180/55 – ZR 17 M/C (73 W) Pirelli Diablo Rosso Corsa II
Fuel Tank Capacity16,5 l (4.36 U.S. gal.)
ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
Battery12 V – 8.6 Ah
Voltage12 V
Alternator350 W at 5.000 r.p.m.
Headlight
Tail Light
Overall Length2.015 mm (79.92 in.)
Overall Width760 mm (28.74 in.)
Trail99 mm (3.89 in.)
Wheelbase1.380 mm (54.33 in.)
Ground Clearance120 mm (4.72 in.)
Seat Height830 mm (32.68 in.)
Dry Weight173 kg (381.4 lbs.)
Warranty
2022 MV Agusta Superveloce 800 Features​
Electronics​
Sport, Race, Rain, Custom: four engine maps dedicated to the Superveloce 800. Four electronic “souls” capable of changing the bike’s character to adapt it to the requirements of the rider, or those of the road. Three of the maps are pre-set, the fourth is fully customisable.
Technology​
The history of MV Agusta permeates every single detail of the Superveloce 800. But beyond its timeless design inspired by the glorious past, it reveals the most modern technology, concentrated in its 173 kg, as well as leading-edge electronics to satisfy the most demanding riders.
Safety​
The brake system features radial four-piston callipers and large-diameter discs. The aim is to offer state-of-the-art brake power and, most of all, confidence-inspiring control, which is fundamental in all circumstances.
2022 MV Agusta Superveloce 800 Photos​
2022 MV Agusta Superveloce 800 2022 MV Agusta Superveloce 800 2022 MV Agusta Superveloce 800 2022 MV Agusta Superveloce 800
2022 MV Agusta Superveloce 800 Videos​
2021 MV Agusta Superveloce 800 First Ride At Barber Motorsports Park
MV Agusta 2021 Reveal: Superveloce
MV Agusta Websites​
Other Links​
The post 2022 MV Agusta Superveloce 800 [Specs, Features, Photos] appeared first on webBikeWorld.
