The 2022 MV Agusta Superveloce Ago Is a Celebration of MV Augusta Greatness
The MV Agusta Superveloce added to its 2022 catalog the new special version, AGO, in honor of Giacomo Agostini, MV Agusta rider during his most successful years.
This nostalgic Italian-made motorbike is limited to 311 units, the first 15 being the most special as they have the personal signature of Giacomo Agostini himself and a plate with unique graphics representing the title and year he won.
The style and design of the MV Agusta Superveloce AGO are inspired by Giacomo Agostini’s MV Agusta 500 3-cylinder in the 1970s, with the classic graphic scheme made up of a red top and a silver side.
The most significant difference compared to the conventional MV Agusta Superveloce, beyond its limitation, is mainly found in the components of the cycle part, with an inverted Öhlins front suspension and the rear monoshock absorber adjustable in preload and hydraulic. We also find spoked wheels, a carbon fiber fender, the chain, and fuel tank protector, a single-seater lid, red grips, and a leather strap on the tank.
The Superveloce Ago comes with a three-cylinder 798cc engine with 147 hp and 88 Nm. Furthermore, with the racing kit (which is free in this AGO version), we discover an Arrow exhaust system with “Ago” serigraphy on its exterior grille and its corresponding adjustment in the engine map, increasing the maximum power figure to 151 hp.
The 2022 MV Agusta Superveloce Ago starts at $35,175 USD / $42,000 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 MV Agusta Superveloce Ago in one place.
- Price: $35,175 USD / $42,000 CAD
- 147 hp 798 cc 3-cylinder engine
- Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
- Integrated ignition – injection system MVICS 2.1 (Motor & Vehicle Integrated Control System) with six injectors
- Front Öhlins Nix “UPSIDE DOWN” telescopic hydraulic fork and Progressive Öhlins TTX, single shock absorber both with rebound and compression damping and spring preload adjustment
- Engine: 798 cc, 4-stroke, 3-cylinder, liquid-cooled, 12 valve DOHC
- Power: 147 hp (108 kW) at 13,000 rpm
- Torque: 65 lb-ft (88 Nm) at 10,100 rpm
- Wet Weight: 421 lbs (191 kg)
- Seat Height: 32.6 in. (830 mm)
- Suzuki Katana
- Bimota KB4
- Yamaha XSR900
2022 MV Agusta Superveloce Ago Specifications
Engine | 798 cm3 (48.7 cu. in.), Three cylinders, 4 stroke, 12 valves |
Power | 147 Hp |
Bore x Stroke | 79 mm x 54.3 mm (3.1 in. x 2.1 in.) |
Compression Ratio | 13.3:1 |
Timing system | “D.O.H.C” with mechanical chain tensioner and DLC tappet |
Color | Matt Ago Yellow, Matt Fried Red, Matt SV Ago Magnum Silver |
Clutch | Wet, multi-disc slipper clutch |
Transmission | Cassette style; six speed, constant mesh |
Final Drive Ratio | 17/43 |
Suspension Front | Öhlins Nix “UPSIDE DOWN” telescopic hydraulic fork with rebound-compression damping and spring preload external and separate adjustment |
Suspension Rear | Progressive Öhlins TTX, single shock absorber with rebound and compression damping and spring preload adjustment |
Brakes Front | Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange |
Brakes Rear | Single steel disc with Ø 220 mm (Ø 8.66 in.) dia. |
Tires Front | 120/70 – ZR 17 M/C (58 W) Pirelli Diablo Rosso Corsa II |
Tires Rear | 180/55 – ZR 17 M/C (73 W) Pirelli Diablo Rosso Corsa II |
Fuel Tank Capacity | 16,5 l (4.36 U.S. gal.) |
ABS System | Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function |
Battery | 12 V – 8.6 Ah |
Voltage | 12 V |
Alternator | 350 W at 5.000 r.p.m. |
Headlight | |
Tail Light | |
Overall Length | 2.015 mm (79.92 in.) |
Overall Width | 760 mm (28.74 in.) |
Trail | 99 mm (3.89 in.) |
Wheelbase | 1.380 mm (54.33 in.) |
Ground Clearance | 120 mm (4.72 in.) |
Seat Height | 830 mm (32.68 in.) |
Dry Weight | 173 kg (381.4 lbs.) – 165 kg (363,8 lbs.) |
Warranty | |
Extension |
2022 MV Agusta Superveloce Ago Features
Electronics
Electronics package is focused on the MVICS 2.1 platform, which controls 6 fuel injectors, interfaces with the inertial platform, manages 4 engine maps and 8-level traction control. In addition, the MV EAS 3.0 (Electronically Assisted Shift up & down) contributes to offering even more lightning-fast and precise shift changes. The new Superveloce Ago features a special kit, which includes a control unit that allows the rider to get the most out of the road-approved Arrow exhaust system (optional).Technology
The new Superveloce Ago unique kit includes the captivating Arrow exhaust system (road-approved), immediately recognizable by two tail pipes on the right side and one on the left; the triple overlapping muffler is instead fitted as standard. What’s more, the Arrow asymmetrical exhaust not only significantly guarantees an increase in power and torque but also contributes to intensify the Superveloce Ago sporty character. To be true, this new-born seems to remember the racing bikes of the past, protagonists of many glorious victories. The MV Agusta Superveloce Ago kit overwhelms also thanks to numerous carbon fibre components, included the seat cowl fitted with Alcantara pad, a pair of appealing red grips, a special bike cover as well as a certificate guaranteeing the authenticity of the limited series.Safety
Like all the bikes in the Superveloce range, the Ago limited edition boasts a rich safety package, starting with the Brembo braking system. This choice guarantees not only extraordinary on-road and track performance, specifically in terms of power and control, but also the whole system takes advantage of the ABS Continental MK100 module, which includes cornering function. The result? Safe braking, thanks to active anti-lock braking even when cornering.2022 MV Agusta Superveloce Ago Photos
2022 MV Agusta Superveloce Ago Videos
2022 MV Agusta Superveloce Ago UNBOXING
NEW 2022 MV Agusta Superveloce Ago Edition: 5 Best Features!
MV Agusta Websites
Other Links
The post 2022 MV Agusta Superveloce Ago [Specs, Features, Photos] appeared first on webBikeWorld.
