2022 MV Agusta Turismo Veloce RC SCS [Specs, Features, Photos]
2022 MV Agusta Turismo Veloce RC SCS Is the Family’s Racy Tourer​
The MV Agusta Turismo Veloce RC SCS is perhaps the most exclusive and advanced sport touring in the brand’s 2022 lineup and the entire medium displacement segment.
This model is equipped by the Reparto Corse competition department, of which there are only 300 units, and its redesigned livery is reminiscent of the brand’s competition models. In addition, it has components such as the SCS automatic gearbox and other details that make it even more exclusive.
This Italian motorbike flaunts excellent equipment for a travel experience that is second to none in terms of safety, comfort, and riding pleasure.
Turismo Veloce RC SCS focuses less on pure performance and the pursuit of lap time, giving greater attention to fun and comfort. Not for this, however, they give up some racing goodies and an almost track-like attitude that is not lost with the SCS system (Smart Clutch System), which limits the use of the clutch.
The 2022 MV Agusta Turismo Veloce RC SCS has a serial number inscribed on the stem and is accompanied by a certificate of authenticity. In addition, it has received some improvements over the previous model, such as a new exhaust design, a new suspension configuration, a larger windshield, a more precise and reliable electronic transmission, and a new IMU inertial unit.
The 2022 MV Agusta Turismo Veloce RC SCS starts at $24,700 USD / $31,600 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 MV Turismo Veloce RC SCS in one place.
  • Price: $24,700 USD / $31,600 CAD
    • 110 hp 798 cc 3-cylinder engine
    • Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
    • S.C.S. 2.0 (Smart Clutch System) Radius CX automatic clutch with hydraulic clutch actuation, wet multi-disc
    • Integrated ignition – injection system MVICS 2.1 (Motor & Vehicle Integrated Control System) with three injectors.
Main Specs​
  • Engine: 798 cc, 4-stroke, 3-cylinder, liquid-cooled, 12 valve DOHC
  • Power: 110 hp (81 kW) at 11,000 rpm
  • Torque: 62 lb-ft (84 Nm) at 8,500 rpm
  • Wet Weight: 491 lbs (223 kg)
  • Seat Height: 33.46 in. (850 mm)
Competitors​
2022 MV Agusta Turismo Veloce RC SCS Specifications​
Engine798 cm3 (48.7 cu. in.), Three cylinders, 4 stroke, 12 valves
Power110 Hp
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio13.4:1
Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappet
ColorRc Pearl White Ago Red, Emerald Green
ClutchS.C.S. 2.0 (Smart Clutch System) Radius CX automatic clutch with hydraulic clutch actuation, wet multi-disc
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio16/39
Suspension FrontSachs “UPSIDE DOWN” semi-active telescopic hydraulic fork MVCSC (MV Agusta Chassis Stability Control)
Suspension RearProgressive, Sachs semi-active single shock absorber with hydraulic spring preload adjustment MVCSC (MV Agusta Chassis Stability Control)
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear190/55 – ZR 17 M/C (75 W)
Fuel Tank Capacity21.5 l (5.68 U.S. gal.)
ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
Battery12 V – 11 Ah
Voltage12 V
Alternator450 W at 5.000 r.p.m.
Headlight
Tail Light
Overall Length2.125 mm (83.66 in.)
Overall Width910 mm (35.83 in.)
Trail108 mm (4.25 in.)
Wheelbase1.445 mm (56.89 in.)
Ground Clearance140 mm (5.51 in.)
Seat Height830 mm (32.68 in.)
Dry Weight199 kg (438.72 lbs.)
Warranty
2022 MV Agusta Turismo Veloce RC SCS Features​
Electronics​
The GPS is integrated into the instrumentation. Cruise control comes as standard, offering maximum comfort in all conditions, because the sportiest Turismo Veloce of all time doesn’t forget its primary vocation — to travel — emphasised also by its very name.
Technology​
Equipped with Front Lift Control (FLC), traction control and a more efficient and precise inertial platform, the Turismo Veloce RC SCS has the very best technology in its segment, while unpleasant setbacks are prevented with the Mobisat satellite locator.
Safety​
The new Continental MK100 ABS module with cornering function ensures maximum safety, even through the turns. The electronic gearbox is faster and even more precise, while new 5.5” colour TFT instrumentation allows all information to be kept under control, even on the sportiest of Turismo Veloce models.
2022 MV Agusta Turismo Veloce RC SCS Photos​
2022 MV Agusta Turismo Veloce RC SCS 2022 MV Agusta Turismo Veloce RC SCS 2022 MV Agusta Turismo Veloce RC SCS 2022 MV Agusta Turismo Veloce RC SCS
2022 MV Agusta Turismo Veloce RC SCS Videos​
MV Agusta RC range – 2022
New 2022 MV Agusta RC Lineup Announced! (F3 RC, Dragster RC, Turismo Veloce RC)
MV Agusta Websites​
Other Links​
The post 2022 MV Agusta Turismo Veloce RC SCS [Specs, Features, Photos] appeared first on webBikeWorld.
