2023 MV Agusta Dragster RC SCS [Specs, Features, Photos]
Unfiltered Exhilaration On The 2023 MV Agusta Dragster RC SCS
The 2023 MV Agusta Dragster RC SCS is the epitome of power, style, and cutting-edge technology. At the heart of the Dragster RC SCS lies a three-cylinder, 798cc engine that churns out an impressive 140 horsepower with 12 valves and a double overhead camshaft and DLC tappet. The engine is cooled by separated liquid and oil radiators, ensuring optimal temperature even in the most demanding conditions. One of the most remarkable features of the Dragster RC SCS is its innovative Smart Clutch System (SCS).
This advanced technology allows for seamless shifts of the six-speed cassette style gearbox without the need for a clutch lever, making your rides smoother and more enjoyable. The Continental ABS system with Rear Wheel Lift-up Mitigation (RLM) and cornering function ensures safety at all times.
The Dragster RC SCS is a true work of Italian art, combining aggressive lines and a muscular stance which is complemented by the RC only paint scheme that draws attention wherever you go. The Dragster RC SCS features an ALS steel tubular trellis frame that provides a firm foundation for the bike’s performance. The front suspension is a Marzocchi upside down fork with a TIN aluminum treatment and anodized fork legs, while the rear suspension is Sachs single shock.
MV Agusta has packed the Dragster RC SCS with a range of cutting-edge features to enhance your riding experience. The advanced TFT dashboard provides clear and intuitive information at a glance, keeping you informed without distractions. Additionally, the Dragster RC SCS boasts a comprehensive suite of electronic aids, including multiple riding modes, traction control, cruise control and more to ensure optimal performance and safety.
As if all that wasn’t enough, MV has an optional Race Kit to make this model even more exclusive. Opt for the SC Project race exhaust and you receive a special ECU mapping to take full advantage of its performance. The clear clutch cover stands out visually and makes this limited model even more exclusive. Performance is further enhanced by the roughly 18 pound weight loss due to this upgrade!
The 2023 MV Agusta Dragster RC SCS starts at $26,398 USD/$28,448 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 MV Agusta Dragster RC SCS in one place.
2023 MV Agusta Dragster RC SCS2023 MV Agusta Dragster RC SCS
  • Price: $26,398 USD/$28,448 CAD
    • Brembo braking system with ABS, Rear Lift-up Mitigation
    • Carbon fiber bodywork and RC only color scheme
    • EAS 3.0 electronic clutch with hill assist
    • MV Ride with GPS navigation and Bluetooth
  • Engine: 798 cc Three cylinder, 4 stroke, 12 valve
  • Power: 140 horsepower
  • Torque: 64 ft-lbs
  • Weight: 370 lbs (168 kgs)
  • Seat Height: 33.27 inches (845 mm)
2023 MV Agusta Dragster RC SCS Specifications​
Engine798 cm3 (48.7 cu. in.), Three cylinders, 4 stroke, 12 valves
Power140 Hp
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio13.3:1
Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappet
Color
ClutchS.C.S. 2:0 (Smart Clutch System) Radius CX automatic clutch with hydraulic cluch actuation, wet multi-disc
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio16/41
Suspension FrontMarzocchi “UPSIDE DOWN” telescopic hydraulic fork with TIN treatment aluminium and anodized fork legs, rebound-compression damping and spring preload external and separate adjustment
Suspension RearProgressive, Sachs single shock absorber with rebound and compression damping and spring preload adjustment
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear200/55 – ZR 17 M/C (78 W)
Fuel Tank Capacity16,5 l (4.36 U.S. gal.)
ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
Battery12 V – 8.5 Ah
Voltage12 V
Alternator350 W at 5.000 r.p.m.
Headlight
Tail Light
Overall Length2.035 mm (80.51 in.)
Overall Width935 mm (36.81 in.)
Trail103.5 mm (4.07 in.)
Wheelbase1.400 mm (55.12 in.)
Ground Clearance135 mm (5.31 in.)
Seat Height845 mm (33.27 in.)
Dry Weight168 kg (370.38 lbs.) – 160 kg (352.74 lbs.)
Warranty
2023 MV Agusta Dragster RC SCS Features​
Electronics​
The Dragster RC SCS comes with GPS and Bluetooth as standard, navigation integrated into the instrumentation, and a Mobisat satellite locator, but that’s not all, as it can also count on a comprehe and very reliable package of electroni6 controls.
Technology​
The EAS 3.0 electronic clutch with hill assist is even quicker and more efficient, perfect for enhancing the SCS system. As a result, the rider need focus only on the road ahead, enjoying every second aboard the Dragster RC SCS.
Safety​
The Brembo braking system with Continental MK100 ABS allows for race-level braking as well as easy and immediate deceleration control. The Rear Wheel Lift-Up Mitigation (RLM) system prevents any lifting of the rear wheel, while the cornering function ensures a high level of safety, even when braking through the turns.
2023 MV Agusta Dragster RC SCS Photos​
2023 MV Agusta Dragster RC SCS 2023 MV Agusta Dragster RC SCS 2023 MV Agusta Dragster RC SCS 2023 MV Agusta Dragster RC SCS
2023 MV Agusta Dragster RC SCS Videos​
2023 MV Agusta Dragster RC SCS Review by A D I:
2023 MV Agusta Dragster RC SCS review by MotoRevs27:
MV Agusta Websites​
Other Links​
The post 2023 MV Agusta Dragster RC SCS [Specs, Features, Photos] appeared first on webBikeWorld.
