2023 MV Agusta Dragster RR SCS [Specs, Features, Photos]
The 2023 MV Agusta Dragster RR SCS: Power, Precision, And Performance
The 2023 MV Agusta Dragster RR SCS is a marvel of Italian motorcycle craftsmanship, merging high performance with stunning design. Under the hood, the Dragster RR SCS is powered by a three-cylinder, four-stroke 798cc engine making a staggering power output of 140 horsepower.
Helping you control this beat is a myriad of features that set this motorcycle apart from others in the class. The Smart Clutch System features a Radius CX automatic clutch which means that you can experience smooth, seamless gear shifts without having to manually operate the clutch when shifting up or down. Combined with the six-speed, constant mesh transmission, the Dragster RR SCS delivers a riding experience that’s as smooth as it is exhilarating.
Like other models in the 2023 MV Augusta lineup, the Dragster RR SCS is built on an ALS steel tubular trellis frame, renowned for its high strength-to-weight ratio. This sturdy construction ensures that the Dragster RR SCS can handle the stress of high speeds and tight turns. The front suspension setup is shared with several other MV Agusta motorcycles and features a Marzocchi fork while the rear suspension uses a Sachs single shock. This advanced suspension system ensures optimal handling and comfort, whether you’re cruising down the highway or carving your way through winding mountain roads. The Dragster RR SCS also features a Brembo braking system with ABS, courtesy of Continental’s MK100 system ensuring superior stopping power and safety. An adjustable steering damper allows you to personalize the riding characteristics.
The 2023 MV Agusta Dragster RR SCS starts at $23,398 USD/$25,248 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 MV Agusta Dragster RR SCS in one place.
2023 MV Agusta Dragster RR SCS2023 MV Agusta Dragster RR SCS
  • Price: $23,398 USD/$25,248 CAD
    • Brembo radial 4 piston calipers with dual 320mm discs
    • Carbon fiber bodywork
    • Marzocchi upside down forks
    • MV Ride App – GPS
  • Engine: 798 cc Three cylinder, 4 stroke, 12 valve
  • Power: 140 horsepower
  • Torque: 64 ft-lbs
  • Weight: 385 lbs (175 kgs)
  • Seat Height: 33.3 inches (845 mm)
2023 MV Agusta Dragster RR SCS Specifications​
Engine798 cm3 (48.68 cu. in.), Three cylinder, 4 stroke, 12 valve
Power140 Hp
Bore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)
Compression Ratio13.3:1
Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappet
ColorRosso Fucodo, Nero Intenso
ClutchS.C.S. 3.0 (Smart Clutch System) Radius CX automatic clutch with hydraulic actuation
TransmissionCassette style; six speed, constant mesh
Final Drive Ratio16/41
Suspension FrontMarzocchi “UPSIDE DOWN”, telescopic hydraulic fork with DLC treatment and anodized fork legs, rebound-compression damping and spring preload external and separate adjustment
Suspension RearProgressive, Sachs single shock absorber with rebound and compression damping and spring preload adjustment
Brakes Front
Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange
Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.
Tires Front120/70 – ZR 17 M/C (58 W)
Tires Rear200/55 – ZR 17 M/C (78 W)
Fuel Tank Capacity16.5 l (4.36 U.S. gal.)
ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function
Battery12 V – 8.6 Ah
Voltage12 V
Alternator350 W at 5000 r.p.m.
Headlight
Tail Light
Overall Length2035 mm (80.12 in.)
Overall Width935 mm (36.81 in.)
Trail103.5 mm (4.07 in.)
Wheelbase1400 mm (55.12 in.)
Ground Clearance135 mm (5.31 in.)
Seat Height845 mm (33.27 in.)
Dry Weight175 kg (385.8 lbs.)
Warranty
2023 MV Agusta Dragster RR SCS Features​
Electronics​
The SCS 3.0 system allows a perfect match between the clutch action and the delivery curve of the three-cylinder. And the MV EAS 3.0 gearbox (Electronically Assisted Shift Up & Down) is a marvel of precision and ease of use.
Technology​
The SCS 3.0 system doesn’t really change the way the rider interacts with the motorcycle: the clutch control, shift and gears are still just where you’d expect to find them, with the bonus option of simply deciding not to use the clutch. For extreme functionality, without sacrificing anything.
Safety​
The braking system has evolved and is lighter, more powerful and easier to use. The Brembo M4.32 front callipers weight 200 grams less and provide much higher performance. The MK100 Continental ABS with Rear wheel Lift-Up Mitigation with cornering function provides safety even in turns.
2023 MV Agusta Dragster RR SCS Photos​
2023 MV Agusta Dragster RR SCS 2023 MV Agusta Dragster RR SCS 2023 MV Agusta Dragster RR SCS 2023 MV Agusta Dragster RR SCS
2023 MV Agusta Dragster RR SCS Videos​
2023 MV Agusta Dragster RR SCS Review by Spinpov:
2023 MV Agusta Dragster RR SCS review by MotoRevs27
MV Agusta Websites​
Other Links​
The post 2023 MV Agusta Dragster RR SCS [Specs, Features, Photos] appeared first on webBikeWorld.
