The 2023 MV Agusta Dragster RR Is A Raw Blend Of Technology And Design
Meet the 2023 MV Agusta Dragster RR, a motorcycle that embodies the spirit of a street fighter, packed into a compact and aggressive package. While at the lower end of the 2023 MV Agusta lineup as far as price, it doesn’t disappoint anywhere. At the heart of the Dragster RR is a three-cylinder, four-stroke engine with a total displacement of 798 cubic inches (48.68 cubic inches). Internal friction has been further reduced due to the DLC coating on the new tappets and the different materials used for the valve guides. It packs 140 horsepower and 64.2 ft-lb of torque into a very compact package. The six-speed, constant mesh transmission allows precise control of the gears for an exceptional experience.
The Dragster RR is not just about power, it’s also about precise control. It compares favorably in the technology department to other MV Agusta motorcycles. The bike’s electronics have seen a huge improvement, with a new IMU inertial platform that enables the traction control to be managed with precise sensitivity based on the lean angle The bike is outfitted with an integrated ignition-injection system MVICS 2.1 and a full ride-by-wire throttle body by Mikuni. The engine control unit comes with ion-sensing technology that controls detonation and misfire. You’ll also find an electronic quick-shifter.
Comparing well with other Italian motorcycle manufacturers, the Dragster RR features a steel tubular trellis frame, Marzocchi upside down forks and a Sachs, single shock in the rear. The front and rear brakes are from Brembo, with the ABS system provided by Continental MK100, featuring Rear Wheel Lift-up Mitigation and a cornering function. Other technology packed in the Dragster includes the MV Ride App, cruise control, and launch control. It’s also equipped with aluminum front fender side supports, a tank damper, and a full-LED headlight that features an effective cornering function.
The 2023 MV Agusta Dragster RR starts at $19,998 USD/$22,448 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 MV Agusta Dragster RR in one place.
- Price: $19,998 USD/$22,448 CAD
- Brembo radial 4 piston calipers with dual 320mm discs
- Carbon fiber bodywork
- Marzocchi upside down forks
- MV Ride App – GPS
- Engine: 798 cc Three cylinder, 4 stroke, 12 valve
- Power: 140 horsepower
- Torque: 64 ft-lbs
- Weight: 385 lbs (175 kgs)
- Seat Height: 33.3 inches (845 mm)
2023 MV Agusta Dragster RR Specifications
Engine | 798 cm3 (48.68 cu. in.), Three cylinder, 4 stroke, 12 valve |
Power | 140 Hp |
Bore x Stroke | 79 mm x 54.3 mm (3.1 in. x 2.1 in.) |
Compression Ratio | 13.3:1 |
Timing system | “D.O.H.C” with mechanical chain tensioner and DLC tappet |
Color | Matt Magnum Silver, Matt Metallic Dark Grey, Matt Magnum Avio Grey |
Clutch | Multi-disc wet clutch with hydraulic actuation and back torque limiting device. |
Transmission | Cassette style; six speed, constant mesh |
Final Drive Ratio | 16/41 |
Suspension Front | Marzocchi “UPSIDE DOWN” telescopic hydraulic fork in DLC treated aluminium, with anodized fork legs and having rebound-compression damping and spring preload external and separate adjustment |
Suspension Rear | Progressive Sachs, single shock absorber with rebound and compression damping and spring preload adjustment |
Brakes Front | Double floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange |
Brakes Rear | Single steel disc with Ø 220 mm (Ø 8.66 in.) dia. |
Tires Front | 120/70 – ZR 17 M/C (58 W) |
Tires Rear | 200/55 – ZR 17 M/C (78 W) |
Fuel Tank Capacity | 16.5 l (4.36 U.S. gal.) |
ABS System | Continental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering function |
Battery | 12 V – 8.6 Ah |
Voltage | 12 V |
Alternator | 350 W at 5000 r.p.m. |
Headlight | |
Tail Light | |
Overall Length | 2035 mm (80.12 in.) |
Overall Width | 935 mm (36.81 in.) |
Trail | 103.5 mm (4.07 in.) |
Wheelbase | 1400 mm (55.12 in.) |
Ground Clearance | 135 mm (5.31 in.) |
Seat Height | 845 mm (33.27 in.) |
Dry Weight | 175 kg (385.8 lbs.) |
Warranty | |
Extension |
2023 MV Agusta Dragster RR Features
Electronics
From the dashboard to the ABS, taking in the controls and the firmware of the control unit: the electronics on the new Dragster RR have taken a huge step forward in quality, thanks in part to the arrival of the new IMU inertial platform, which reads the spatial positioning of the motorcycle and enables traction controls to be managed with great sensitivity based on the lean angle.Technology
The weight distribution, the refined chassis and suspension as well as the Dragster’s unique character are the main characteristics of a machine that was created for the most demanding riding enthusiasts.Safety
When you can concentrate purely on riding, you automatically increase the fun. And when safety is covered by a Continental ABS system with cornering function and Rear Wheel Lift-up Mitigation, there’s nothing to worry about. The system mitigates the pressure exerted on the front brake to avoid rear-wheel lift.2023 MV Agusta Dragster RR Photos
2023 MV Agusta Dragster RR Videos
MV Agusta Dragster 800 RR | First Ride | 2022
MV Agusta Dragster RR 2022
MV Agusta Websites
Other Links
The post 2023 MV Agusta Dragster RR [Specs, Features, Photos] appeared first on webBikeWorld.
