2022 Zero FXE [Specs, Features, Photos]
The 2022 Zero FXE Is a Compact, Agile, and Fun Electric Supermoto
The Zero FXE is the latest addition to the 2022 Zero Motorcycle lineup. The supermoto-styled electric motorcycle is based on the Zero FXS and is an agile, lightweight machine most comfortable in the urban jungle.
Equipped with the American company’s ZF7.2 (7.2 kWh total capacity) battery pack, the Zero FXE will take you as far as 100 miles in the city. Get on the highway at a steady 70mph cruise, and that number drops to a humble 40 miles. A full charge with the standard charger takes nearly 10 hours — 9.7 hours, to be precise — so it’s a good idea to spend the extra money on the accessory chargers that bring the time down considerably to 1.8 hours.
The FXE is equipped with the Z-Force 75-5 motor that also powered multiple other models in the Zero Motorcycle portfolio. The motor, producing 46hp and 78 lb-ft of torque, can propel the bike to a top speed of 85mph.
As it typically does, Zero has equipped the FXE with some pretty neat hardware — grippy Pirelli Diablo Rosso II tires, fully adjustable Showa suspension, and Bosch Gen 9 ABS that works alongside braking hardware from J.Juan.
The 2022 Zero FXE starts at $12,195 USD / $15,695 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Zero FXE in one place.
2022 Zero FXE
Motorcycle Overview​
  • Price: $12,195 USD / $15,695 CAD
    • 100 miles range in the city
    • 85mph top speed
    • Bosch Gen 9 ABS
    • Pirelli Diablo Rosso II tires
    • Five-year unlimited mile power pack warranty
Main Specs​
  • Engine: 7.2 kWh
  • Power: 46hp
  • Torque: 78lb-ft
  • Wet Weight: 298 lbs (135 kg)
  • Seat Height: 32.9 inches (836 mm)
Competitors​
2022 Zero FXE
2022 Zero FXE Specifications​
Engine​
Peak torque
78 ft-lb (106 Nm)
Peak power
46 hp (34 kW) @ 4,300 rpm
Top speed (max)
85 mph (137 km/h)
Type
Z-Force® 75-5 passively air-cooled, high efficiency, radial flux, interior permanent magnet, brushless motor
Controller
High efficiency, 550 amp, 3-phase brushless controller with regenerative deceleration
Lubrication
Drivetrain​
Clutch
Final Drive90T / 18T, Poly Chain® HTD® Carbon
belt
Chassis​
Suspension Front
Showa 41 mm inverted cartridge forks, with adjustable spring preload, compression and rebound damping
Suspension RearShowa 40 mm piston, piggy-back reservoir shock with adjustable spring preload, compression and rebound damping
Brakes Front
Bosch Gen 9 ABS, J-Juan asymmetric dual piston floating caliper, 320 x 5 mm disc
Brakes Rear
Bosch Gen 9 ABS, J-Juan single piston floating caliper, 240 x 4.5 mm disc
Tires FrontPirelli Diablo Rosso II 110/70-17
Tires RearPirelli Diablo Rosso II 140/70-17
Fuel Tank CapacityN/A
Color
Power system​
Power pack
Z-Force® Li-Ion intelligent integrated
Charger type
650 W, integrated
Charge time (standard)9.7 hours (100% charged) / 9.2 hours (95% charged)
Dimensions​
Wheelbase
56.0 in (1,422 mm)
Overall Width
Trail
2.8 in (71 mm)
Rake
24.4°
Seat Height32.9 in (836 mm)
Curb Weight
298 lb (135 kg)
Warranty​
Warranty
2 years
2022 Zero FXE
2022 Zero FXE Features​
DESIGN​
Zero partnered with Bill Webb in 2018 on a Custom build of the Zero FXS. Ultimately we wanted to utilize the build to inspire elements of future Zero motorcycles. Many concept builds push the envelope so far it doesn’t translate to the reality of riding and functionality. Bill Webb took a different approach. He set out to create something that pushed the boundary but relatable and something that could become a reality. We were not surprised when the Motorcycle industry loved the bike. This enthusiasm went well beyond our industry.
TECHNOLOGY​
Built on the foundation of the revolutionary Zero ZF 75-5 powertrain and Cypher II operating system, the road before the FXE is always bright thanks to new LED head and tail lights as well as a full color and bonded TFT dash to literally outshine motorcycles well above its station. Brains and brawn.
PERFORMANCE PROFILE​
Transform performance profiles with the press of a button to perfectly conquer city streets or your local supermoto track. The Zero FXE is pre-programmed with Eco or Sport modes. Connect using your mobile device to customize performance or get stats on your ride.
EXPERIENCE​
The FXE is lighter than any motorcycle with this much power, has no gears and clutch, and an upright riding position making it the most user-friendly vehicle on the road. This bike truly becomes a seamless extension of the rider. Gliding effortlessly through traffic has never been so fun. The FXE is the motorcycle rides as smooth as it looks.
2022 Zero FXE Photos​
2022 Zero FXE 2022 Zero FXE 2022 Zero FXE 2022 Zero FXE
2022 Zero FXE Videos​
2022 Zero FXE Review by RevZilla:
2022 Zero FXE Review by Electrek.co:
Zero Motorcycles Websites​
The post 2022 Zero FXE [Specs, Features, Photos] appeared first on webBikeWorld.
