2023 Kawasaki Ninja 400 [Specs, Features, Photos]
The 2023 Kawasaki Ninja 400 Is A Great Sportbike Entry
For 2023, Kawasaki has updated the Ninja 400 ABS which is designed for riders who are looking for a sleek and that can handle both city streets and winding roads while being accessible to newer riders. While the Ninja is powered by the smallest engine of Kawasaki’s Ninja family, the 399cc liquid-cooled, parallel-twin engine still delivers 45 horsepower and 28 lb-ft of torque and a nimble ride. The bike has a six-speed transmission and a slipper clutch, which makes downshifting smoother and easier. The Ninja 400 ABS also comes with a lightweight trellis frame, which improves the bike’s agility and handling. Bringing you to a stop on the Ninja 400 is the single 310mm front disc and a single 220mm rear which provide excellent stopping power and control. ABS is an extra cost add on which adds an extra layer of safety.
The Ninja 400 ABS also includes a digital instrument panel that displays speed, rpm, fuel level, and other information. The seat is designed to be comfortable for both riders and passengers, and the bike has a sleek and aerodynamic fairing that reduces wind resistance at high speeds. The baby ninja includes features that make it competitive with the other Japanese brands in the class and is an excellent choice for those entering the sportbike world.
The 2023 Kawasaki Ninja Ninja 400 starts at: $5,299 USD/$7,299 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Ninja Ninja 400 in one place.
2023 Kawasaki Ninja 4002023 Kawasaki Ninja 400
  • Price: Ninja 400 $5,299 USD/$7,299 CAD
    • 310mm semi-floating front disc brake
    • LED headlights
    • Brembo brakes
    • Lightweight trellis frame
  • Engine: 399 cc liquid-cooled, 4-stroke, DOHC 8-valve parallel twin
  • Power: 44.8 horsepower
  • Torque: 27 lb-ft
  • Weight: 366 lbs (166 kgs)
  • Seat Height: 30.9 inches (785 mm)
2023 Kawasaki Ninja 400 Specifications​
Engine399cc, 4-stroke, Parallel Twin, DOHC, liquid-cooled
Power44.8 Hp
Bore x Stroke70.0 x 51.8mm
Compression Ratio
11.5:1
Fuel SystemDFI® with dual 32mm throttle bodies
Electronic Rider Aids
Clutch
Transmission6-speed
Final DriveSealed chain
Suspension Front41mm hydraulic telescopic fork/4.7 in
Suspension RearHorizontal back-link with adjustable spring preload/5.1 in
Brakes FrontSingle 310mm semi-floating petal-type disc with 2-piston calipers (and ABS)
Brakes Rear
Single 220mm petal-type disc with single-piston caliper (and ABS)
Tires Front110/70-17
Tires Rear150/70-17
Fuel Tank Capacity3.7 gal
Color
Metallic Carbon Gray/Metallic Matte Carbon Gray, Metallic Magnetic Dark Gray/Metallic Matte Twilight Blue, Pearl Blizzard White/Metallic Carbon Gray
IgnitionTCBI w/Digital Advance
HeadlightLED
Overall Length78.3 in
Overall Width28 in
Overall Height44.1 in
Wheelbase53.9 in
Ground Clearance5.5 in
Seat Height30.9 in
Curb Weight366.0 lb (ABS), 361.6 lb (non-ABS)*
Warranty12 Month Limited Warranty
Kawasaki Protection Plus12, 24, 36 or 48 months
2023 Kawasaki Ninja 400 Features​
Assist & Slipper Clutch​
Economical Riding Indicator​
ABS (Anti-lock Brake System)​
ERGO-FIT​
Proper fit is key for rider comfort and control. However, the ideal fit varies from rider to rider, depending on their physical dimensions and riding style.
ERGO-FIT® is an interface system designed to allow riders to find their ideal riding position. Various points of the chassis interface (the handlebar, footpegs and seat, etc.) can be adjusted through a combination of interchangeable parts and parts with adjustable positions. This enables a wide range of riders to find a riding position that offers both comfort and control. Feeling at one with their machine, they will be able to experience how Kawasaki machines are fun and rewarding to ride.
2023 Kawasaki Ninja 400 Photos​
2023 Kawasaki Ninja 400 2023 Kawasaki Ninja 400 2023 Kawasaki Ninja 400 2023 Kawasaki Ninja 400
2023 Kawasaki Ninja 400 Videos​
2023 Kawasaki Ninja Ninja 400 review by Peter Lowe One:
2023 Kawasaki Ninja Ninja 400 Review by Autocar India:
Kawasaki Official Websites​
The post 2023 Kawasaki Ninja 400 [Specs, Features, Photos] appeared first on webBikeWorld.
