2023 Kawasaki Ninja ZX-4R [Specs, Features, Photos]
The 2023 Kawasaki Ninja ZX-4R: A Middleweight Powerhouse
Kawasaki motorcycles has once again upped the ante in the supersport segment with the release of the 2023 Ninja ZX-4R but sadly it won’t be available in the USA. This middleweight sportbike is a force to be reckoned with on both the street and the track that’s sure to please seasoned riders and newcomers alike. The ZX-4R continues the aggressive look that is evident throughout Kawasaki’s 2023 Ninja line . Its sharp, aerodynamic lines coupled with the central ram air give it an imposing presence that distinguishes it from its Japanese motorcycle competitors in the middleweight class.
Kawasaki has equipped the Ninja with a powerful 399cc inline-four engine that’s high-revving nature, while the Assist & Slipper Clutch ensures smooth downshifts and reduced rear-wheel hop.
The ZX-4R boasts a lightweight twin-spar aluminum frame that offers exceptional rigidity and handling. The fully adjustable Showa SFF-BP front fork and horizontally mounted rear shock provide precise, responsive suspension action, allowing riders to tailor the bike’s performance to their preferred riding style.
Kawasaki has outfitted the 2023 Ninja ZX-4R with a comprehensive suite of advanced electronics to enhance rider confidence and control. The bike features a quick-shifter for seamless upshifts, selectable engine modes, and traction control to optimize performance across varying road conditions. The bike also comes with a full-color TFT instrument panel that displays vital information and enables smartphone connectivity for seamless integration with Kawasaki’s Rideology app.
The Ninja ZX-4R’s braking system features Nissin radial-mount monobloc front calipers and a single-piston rear caliper, delivering powerful, precise stopping power. The bike rides on high-performance Bridgestone Battlax Hypersport S22 tires that offer superb grip and stability, further enhancing the riding experience.
The 2023 Kawasaki Ninja ZX-4R starts at NA USD/ $9,999 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Ninja ZX-4R in one place.
Kawasaki Ninja ZX-4RKawasaki Ninja ZX-4R
  • Price: NA USD/ $10,999 CAD
    • Assist & Slipper Clutch
    • Electronics package
    • TFT instrument panel
    • Dual radial-mount front calipers
  • Engine: 399cc, liquid-cooled, 4-stroke, DOHC 16-valve in-line four
  • Power: 75 horsepower (estimated)
  • Torque: 26.5 lb-ft
  • Weight: 414 lbs (188 kgs)
  • Seat Height: 31.5 inches (800 mm)
Kawasaki Ninja ZX-4R Specifications​
Engine399cc, liquid-cooled, 4-stroke, DOHC 16-valve in-line four
Power75 horsepower (estimated)
Bore x Stroke57.0 x 39.1 mm
Compression Ratio
12.3:1
Fuel SystemFuel injection: ø34 mm x 4
LubricationForced lubrication, wet sump
ClutchWet multi-disc, manual
Transmission6-speed, return
Final DriveChain
Suspension Frontø37 mm inverted fork (SFF-BP) with top-out springs / 120 mm (4.7 in)
Suspension RearHorizontal Back-link, gas-charged shock with spring preload adjustability / 112 mm (4.4 in)
Brakes FrontDual semi-floating ø290 mm discs with radial-mount, monobloc, opposed 4-piston calipers
Brakes Rear
ø220 mm disc with single-piston caliper
Tires Front120/70ZR17M/C (58W)
Tires Rear160/60ZR17M/C (69W)
Fuel Tank Capacity15 litres
Color
IgnitionDigital
HeadlightLED
Overall Length78.3 in
Overall Width30.1 in
Overall Height43.7 in
Wheelbase1,380 mm (54.3 in)
Ground Clearance135 mm (5.3 in)
Seat Height800 mm (31.5 in)
Curb Weight188 kg (414 lb)
Warranty12 Months
Kawasaki Protection Plus12 / 24 / 36 / 48 months
Kawasaki Ninja ZX-4R Features​
Assist & Slipper Clutch​
Economical Riding Indicator​
Electronic Throttle Valves​
Kawasaki’s fully electronic throttle actuation system enables the ECU to control the volume of both the fuel (via fuel injectors) and the air (via throttle valves) delivered to the engine. Ideal fuel injection and throttle valve position results in smooth, natural engine response and the ideal engine output. The system also makes a significant contribution to reduced emissions.
Electronic throttle valves also enable more precise control of electronic engine management systems like S-KTRC and KTRC, and allow the implementation of electronic systems like KLCM, Kawasaki Engine Brake Control, and Electronic Cruise Control.
Power Modes​
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.
Smartphone Connectivity​
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.
ABS (Anti-lock Brake System)​
HORIZONTAL BACK-LINK REAR SUSPENSION​
Compared to the Kawasaki traditional Uni-Trak rear suspension, which mounts the shock unit vertically, with Horizontal Back-link Rear Suspension, the shock unit is almost horizontal. The original Kawasaki suspension arrangement locates the shock unit very close to the bike’s center of gravity, greatly contributing to mass centralization. And because there is no linkage or shock unit protruding beneath the swingarm, this frees up space for a larger exhaust pre-chamber (an exhaust expansion chamber situated just upstream of the silencer). With a larger pre-chamber, silencer volume can be reduced, and heavy exhaust components can be concentrated closer to the center of the bike, further contributing to mass centralization. The result is greatly improved handling.
A secondary benefit is that the shock unit is placed far away from exhaust heat. Because it is more difficult for heat from the exhaust system to adversely affect suspension oil and gas pressure, suspension performance is more consistent.
Kawasaki Ninja ZX-4R Photos​
Kawasaki Ninja ZX-4R Kawasaki Ninja ZX-4R Kawasaki Ninja ZX-4R
Kawasaki Ninja ZX-4R Videos​
2023 Kawasaki Ninja ZX-4RR review by Peter Lowe One:
2023 Kawasaki Ninja ZX-4RR Review by MotoBob:
Kawasaki Official Websites​
The post 2023 Kawasaki Ninja ZX-4R [Specs, Features, Photos] appeared first on webBikeWorld.
