2023 Kawasaki Vulcan S Blends Sport Performance with Cruiser Comfort
Kawasaki motorcycles has been a dominant force in the motorcycle world, and its 2023 Vulcan S Sport Cruiser is another impressive addition to Kawasaki’s 2023 motorcycle lineup. This versatile bike is designed to cater to a wide range of riders, offering a comfortable ride with a unique style that combines the essence of both sportbikes and cruisers. At the heart of the 2023 Kawasaki Vulcan S is its powerful and reliable 649cc parallel-twin engine, which is derived from the popular Ninja 650. This fuel-injected, liquid-cooled engine provides ample torque and smooth power delivery, making this Japanese-made motorcycle suitable for both city riding and highway cruises.
The Vulcan S’s Ergo-Fit system sets it apart from its competition. This innovative feature allows riders to customize their seating position, footpeg placement, and handlebar reach. With a combination of adjustable components, the Ergo-Fit system ensures that riders of all sizes and preferences can find their perfect riding position.
The chassis of the 2023 Vulcan S features a high-tensile steel perimeter frame, providing a lightweight yet rigid foundation for the bike. The single-shock rear suspension is adjustable for preload, enabling riders to fine-tune their suspension setup. Braking is handled by a 300mm front disc brake with twin piston calipers and a 250mm rear disc brake, both of which can be complemented by the ABS (Anti-lock Braking System).
The 2023 Kawasaki Vulcan S has a distinctive, modern look that sets it apart from traditional cruisers. Its angular bodywork and sharp lines give it an aggressive, sporty appearance. The stylish headlight, LED taillight, and minimalist instrumentation contribute to the bike’s contemporary aesthetic, making it a head-turner wherever it goes. There is also a Cafe version with a stylish three-tone paint, a small windscreen and other visual updates.
The 2023 Kawasaki Vulcan S / S Cafe starts at $7,349 (non-ABS) USD/ $8,699 (non-ABS) CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Vulcan S / S Cafe in one place.
- Price: $7,349 (non-ABS) USD / $8,699 (non-ABS) CAD
- Adjustable controls
- Adjustable Suspension
- Available ABS
- Custom/Cafe inspired option
- Engine: 649cc, liquid-cooled, 4-stroke, DOHC 8-valve parallel twin
- Power: 50 horsepower (estimated)
- Torque: 58.2 lb-ft
- Weight: 498 lbs (226 kgs)
- Seat Height: 27.8 inches (705 mm)
2023 Kawasaki Vulcan S / S Cafe Specifications
Engine | 649cc, liquid-cooled, 4-stroke, DOHC 8-valve parallel twin |
Power | 50 Hp |
Bore x Stroke | 83.0 x 60.0mm |
Compression Ratio | 10.8:1 |
Fuel System | Fuel injection: ø38 mm x 2 with dual throttle valves |
Lubrication | Forced lubrication, semi-dry sump |
Clutch | Wet multi-disc, manual |
Transmission | 6-speed, return |
Final Drive | Chain |
Suspension Front | ø41 mm telescopic fork / 130 mm (5.1 in) |
Suspension Rear | Offset laydown single-shock, linkage-equipped, with adjustable preload / 80 mm (3.1 in) |
Brakes Front | ø300 mm disc with dual-piston caliper |
Brakes Rear | ø250 mm disc with single-piston caliper |
Tires Front | 120/70R18M/C 59H |
Tires Rear | 160/60R17M/C 69H |
Fuel Tank Capacity | 14 litres |
Color | Metallic Flat Spark Black, Metallic Matte Carbon Gray / Ebony |
Ignition | Digital |
Headlight | LED |
Tail Light | LED |
Overall Length | 90.9 in |
Overall Width | 34.6 in |
Overall Height | 43.3 in |
Wheelbase | 62.0 in |
Ground Clearance | 5.1 in |
Seat Height | 27.8 in |
Curb Weight | ABS: 226 kg (498 lb), non-ABS: 223 kg (492 lb) |
Warranty | 12 Months |
Kawasaki Protection Plus | 12 / 24 / 36 / 48 months |
2023 Kawasaki Vulcan S / S Cafe Features
Dual Throttle Valves
Late-model sport bikes often use large-bore throttle bodies to generate high levels of power. However, with large diameter throttles, when a rider suddenly opens the throttle, the unrestricted torque response can be strong. Dual throttle valve technology was designed to tame engine response while contributing to performance.On models with dual throttle valves, there are two throttle valves per cylinder: in addition to the main valves, which are physically linked to the throttle grip and controlled by the rider, a second set of valves, opened and closed by the ECU, precisely regulates intake airflow to ensure a natural, linear response. With the air passing through the throttle bodies becoming smoother, combustion efficiency is improved and power is increased.
Economical Riding Indicator
ABS (Anti-lock Brake System)
Kawasaki ABS systems use front and rear wheel sensors to constantly monitor wheel speed. Should information from either of the sensors indicate that wheel lock has occurred, the ABS ECU directs the pump in the ABS unit to modulate brake fluid pressure (releasing and reapplying pressure so that traction can be regained) until normal operation resumes. ABS offers rider reassurance that contributes to greater riding enjoyment.ERGO-FIT
Proper fit is key for rider comfort and control. However, the ideal fit varies from rider to rider, depending on their physical dimensions and riding style.ERGO-FIT® is an interface system designed to allow riders to find their ideal riding position. Various points of the chassis interface (the handlebar, footpegs and seat, etc.) can be adjusted through a combination of interchangeable parts and parts with adjustable positions. This enables a wide range of riders to find a riding position that offers both comfort and control. Feeling at one with their machine, they will be able to experience how Kawasaki machines are fun and rewarding to ride.
*Adjustable parts and their range of adjustability vary by model.
2023 Kawasaki Vulcan S / S Cafe Photos
2023 Kawasaki Vulcan S / S Cafe Videos
2023 Kawasaki Vulcan S / S Cafe review by Peter Lowe One:
22023 Kawasaki Vulcan S / S Cafe Review by MotoJitsu:
Kawasaki Official Websites
The post 2023 Kawasaki Vulcan S / S Cafe [Specs, Features, Photos] appeared first on webBikeWorld.
