2023 Kawasaki Vulcan 900 [Specs, Features, Photos]
The 2023 Kawasaki Vulcan 900: A Vintage Cruiser for the Modern Rider
The 2023 Kawasaki Vulcan 900 is a classic cruiser motorcycle designed to cater to riders who crave the perfect blend of power, comfort, and style. It combines modern technology with a vintage aesthetic to offer a memorable riding experience. The Kawasaki motorcycle engineers have built the Vulcan 900 on a sturdy, high-tensile steel frame. This foundation provides both stability and rigidity, ensuring that the bike can handle whatever the road throws at it. The front suspension consists of a 41mm hydraulic telescopic fork, while the rear suspension features a Uni-Trak swingarm with a seven-way adjustable spring preload. This setup allows for a comfortable ride, and Kawasaki has paid close attention to the Vulcan 900’s ergonomics, ensuring that riders of various sizes can enjoy a comfortable ride. The low, 26.8-inch seat height, combined with forward-mounted footpegs and a pullback handlebar, creates a relaxed riding position. One of the key features that sets the Vulcan apart from other Japanese branded cruisers is its 903cc V-twin engine. This fuel-injected, liquid-cooled engine delivers impressive torque and horsepower, and the smooth shifting 5-speed transmission, ensuring smooth shifts and a broad powerband.
The 2023 Vulcan 900 comes in several versions with the classic having the basic cruiser design, featuring a large, sculpted fuel tank, a wide rear fender, and plenty of chrome accents. The bike’s wire-spoke wheels, whitewall tires, and round headlamp further enhance its vintage appeal. The Vulcan 900 is available in three different variants: the base Classic model, the Classic LT, and the Custom. Each model comes with unique features and design elements to cater to different rider preferences. So whether you prefer drag bars, white walls or a windscreen for comfort, Kawasaki has a model in their vast 2023 lineup for you!
The 2023 Kawasaki Vulcan 900 starts at $8,999 USD/$12,399 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Vulcan 900 in one place.
2023 Kawasaki Vulcan 9002023 Kawasaki Vulcan 900
  • Price: $8,999 USD/$12,399 CAD
    • 5.3 gallon fuel tank
    • Floorboards with heel/toe shifter
    • Classic whitewall tires and spoked wheels
    • Tank mounted instrumentation
  • Engine: 903cc, liquid-cooled, 4-stroke, SOHC 8-valve V-twin
  • Power: 50 horsepower
  • Torque: 58.2 lb-ft
  • Weight: 657lbs (298 kgs)
  • Seat Height: 26.8 inches (680 mm)
2023 Kawasaki Vulcan 900 Specifications​
Engine903 cc 4-stroke, 55-degree V-twin, liquid-cooled
Power50 HP
Bore x Stroke88.0 x 74.2mm
Compression Ratio
9.5:1
Fuel SystemDFI 34mm Throttle Bodies (2), with sub-throttle
valves
Lubrication
Clutch
Transmission5-speed with positive neutral finder
Final DriveKevlar-reinforced belt
Suspension Front41mm Showa telescopic fork/5.9 in
Suspension RearUni-Trak® swingarm, 7-way adjustable spring preload/4.1 in
Brakes FrontSingle 300mm hydraulic disc
Brakes Rear
Single 270mm hydraulic disc
Tires Front130/90-16
Tires Rear180/70-15
Fuel Tank Capacity5.3 gal
Color
Metallic Spark Black/Metallic Magnesium Gray
IgnitionTCBI w/ Electronic Advance
HeadlightLED
Overall Length97.0 in
Overall Width39.6 in
Overall Height41.9 in
Wheelbase64.8 in
Ground Clearance5.3 in
Seat Height26.8 in
Curb Weight619.6 lb*
Warranty12 Months
Kawasaki Protection Plus12, 24, 36 or 48 months
2023 Kawasaki Vulcan 900 Features​
Dual Throttle Valves​
2023 Kawasaki Vulcan 900 Photos​
2023 Kawasaki Vulcan 900 2023 Kawasaki Vulcan 900 2023 Kawasaki Vulcan 900 2023 Kawasaki Vulcan 900
2023 Kawasaki Vulcan 900 Videos​
2023 Kawasaki Vulcan 900 review by Peter Lowe One:
2023 Kawasaki Vulcan 900 Review by College Bike Shop:
Kawasaki Official Websites​
The post 2023 Kawasaki Vulcan 900 [Specs, Features, Photos] appeared first on webBikeWorld.
