jesse096
I have a plan for my nc700 that might involve using a big bore/stroker kit. Is there a manufacturer that produces a kit for the nc700x?
-Jesse
-Jesse
I have a plan for my nc700 that might involve using a big bore/stroker kit. -Jesse
It's fuel injected, shouldn't be that hard if I can find someone witha laptop and tuning software, or use a power commander.
-Jesse
Stroke... I can see the crankcase being a serious limiting factor unless it's not strong enough to handle the power. Same thing for the crank and both are probably over designed for strength to increase life.Anyone has seen the crankcase design of the NC engine? I doubt a bigger bore is possible...
...If anything the bigger pistons would be more economical, working less to get to a desired speed.
Then put a Gold Wing motor in it and get triple the mileage. It won't even know that there is a motorcycle attached to it.
I agree with Beemerphile, why! Not the purpose of this bike. But folks do spend thousands for just 1 more knot on a boat. So, why not!
