Old Can Ride
But wouldn't it be nice to have a Lamborghini with the fuel efficiency of a Nissan Leaf?!?!
LOL !!
That's pronounced Tesla.
So possible area's of improvement:
- Free flow intake filter
- Get rid of the Cat / add aftermarket exhaust
- Couple more teeth on the back sprocket for more go off the line at the expense of higher rpm at cruise
- Swap a lithium battery in place of the lead acid chunk for weight savings. Side benefit of lowering the center of gravity as the battery is fairly high up.
- Duct tape muzzle for the nay sayers...
Yep, lighter rear sprocket, lighter wheels and brake rotors, remove passenger footpegs (if you can), fender eliminator. It all adds up but can get expensive really fast
I don't think getting a hot cam in this bike would be un-realistic. I'm a little confused myself as to why Honda timed each cylinder a bit different, makes me think that one jug runs better than the other. In an economy minded bike that seems a little odd, why not make them both run "better" and get more power and fuel economy as a result?
The cam timing difference is not to make one cylinder work better than the other, it's to make them both work the same. The 270 degree crank along with the common air intake presents a challenge in getting the air flow consistent between the the two cylinders. Read about it on the Web.
As for boring out the cylinders, as mentioned in an earlier post, apparently Honda was able to do it. The assumption, since the method has not yet been disclosed, is that the upcoming NC750 will have a slightly bigger cylinder bore.
Greg
Point me in the direction where I can read this stuff, because all the internet would tell me was it was for character and to give the engine a more "lumpy" feel.
Yup then I sit my 275# butt on the seat and all the weight savings and $$$ spent mean nothing!!.
