serge
Greetings! I had a front wheel off for tire replacement and put new front brake pads (not OEM). Noticed they are dragging a bit and after a month they are still dragging.. ordered other brand and checked the thickness - the same as I had installed before. I went through sequence for the install in the manual again - loosen caliper bolts, torqued the axle, tighten the caliper bolts, bounced the forks several time, tighten pinch bolt. Still there is some drag ...
Couple questions: I used the backing plate and shim from original inner brake pad. Now I am thinking if aftermarkets ones designed to be installed without any shims ?
Also, I noticed there is some gap between left fork leg and a collar (see photo).. Is it how it is supposed to be? I did not not pay attention to that before I took the wheel off. I checked that right and left collars supposed to be identical, so I ruled out unintentional swap..
