MZ5
If anyone is still interested in the original question, I have not seen any evidence that the NC700XC's non-ABS brakes are linked. That is, I have not noticed a brake line running forward from the foot pedal to the fork area.
I do not believe the brakes are linked. Front and rear are each independent systems.
The dual-channel ABS system developed by Bosch continues as standard equipment on the 990 SM T, but has the feature to be switched off depending on riding conditions. Stopping the Supermoto T are dual 305mm discs with four-piston Brembo calipers up front, and a 240mm rotor with two-piston caliper out back.
Same for the ABS NC's owners, they'll tell you they are a better choice... Go figure... I cannot even get a Non-ABS NC here in Canada, so YES, I'll tell you that the ABS version is better !
It is also fine with me that everyone that likes ABS and wouldn't own a bike without it thinks they are smarter than I am. Doh. However, being smarter than me is not much of a distinction. I don't make any judgements about the intelligence level of people who choose differently.
As offered, I don't want it. I am not against ABS but I would not own this particular implementation of it.
Beemer, I don't know where this reply is coming from and who told you they are smarter than you, bacause I cannot find such statement in this thread.
Technically speaking, wouldn't it be possible to remove the delay valve on the front caliper, cap the output on the ABS modulator to that valve, and bridge the 3rd piston to the two others ? I don't know on which line the modulator has its effect, on the outer pistons, the center one, or all 3 ?
Homer is not the icon of intellect.
I don't know if that would work or not, but if I was saddled with combined brakes I would be experimenting with it.
