D
Deleted member 4372
I picked up the highly praised Tuono shock from an Aprilia shop in Texas. Shiny and clean I'm eager to install it.
The manual is bare bones. My research shows some of you removed the right side plastics; others didn't. Nowhere has my searching revealed a step by step, do it this way (you idiot!) guide to shock replacement.
My hands can barely squeeze in next to the top nut and bolt. Can't seem to get a socket+wrench+hand in there. So must I remove the fairing? I did the left side a couple of weeks ago and found it to be a hassle to reassemble. Managed to mangle a few plastic joiner clips and lost a few things to the bowels of the bike.
Anyone have a direct, straightforward, relatively simple method for removing and replacing the shock?
Will I have to suck it up and remove the right-side plastics or is there another way?
Bear in mind that I'm not the greatest wrencher in the world, so simple but time consuming beats quick but complex every time. Time, I have. Skill, not so much.
TIA, ladies and gentlemen
