duk2n
I have installed a coolant temp meter to my baby.
Materials: Indicator, 22mm hose adapter and patiente. The first two ones are from Koso, the third is from my own
The first thing to nude the right side of the bike. Then, loosen the radiator cap. There is a very small screw in the cap that needs to be loosen before the cap.
With a small silicon hose attached to a syringe, extract about 250 cc of coolant from the radiator. Then, dismount the upper flange, cut the hose and install the adapter and sensor:
Then, inyect back the coolant extracted previously.
I placed the indicator over the stock dashboard:
There is a screw in the back side of the dashboard that is perfect to fix a small self-made support there:
Finally, install again the right side panel.
Finished product:
The hose adaptor is almost hidden with the side panel in place:
You have to be very close to see it:
I did a test of the kit and found that the fan fires at 100 ºC, and disconnects at 95 ºC
HTH
Nov 19th 2012 update
I moved the indicator below the dashboard. I was thinking to install something here but finally I would do it in another way. I think now is better:
Finished product:
HTH
