RubyRider
I have gotten a new job that requires long hours, due to this I will be riding after sundown, I am looking for the easiest way to add some light to my bike. Any suggestions?
It is easy if you buy all the wiring and parts Honda requires to use it.It is easy to get switched power from the 6P accessory connector. It's under the plastic covers on the left side (clutch lever side) of the bike.
WOW.....thanks!It is easy if you buy all the wiring and parts Honda requires to use it.
The harness that plugs into the 6P connector has 3 leads that all require either matching connectors or cutting off Honda's connectors and installing your own.
A fuse block requires no connectors, just bare ends to fit under screws.
And a fuse block gives more options than the 6P harness.
Eastern Beaver sells 6P harness adapters that are more user friendly:
Click on the link above to see all the wiring that Eastern Beaver offers specifically for the NC series.
This is their 6P connector with bare leads
Unsolicited advice with apologies. If you've got it apart, and are running lights, install Skene Photon Blasters. They are a little pricey but worth their weight in gold in both day and night riding.I have gotten a new job that requires long hours, due to this I will be riding after sundown, I am looking for the easiest way to add some light to my bike. Any suggestions?
