V-FORE
Hi all I am trying to figure out my problem, I just read fuzzys thread on his fuel pump. A little history, bought my NC700X new 10/28/12, she is my commuter right now she has a little over 32k on her. The problem started the other morning on the way to work. She seemed down on power and will not idle I have to keep the rpms up. I just changed the plugs & air filter for the 1st time...air filter was fine, plugs looked like it has been running quite rich. I checked spark on both new plugs, it was good. Fired her up and it seems to run at less than 100% so I decide to wait a day and check the valves tonight for kicks. I did a compression check 155 & 160#s which seems fine. I will verify that both cylinders are working after I check the valves. Has anyone else had any problems like this ? There is no faults on the idiot lights and my thoughts are that most likely one of the injectors is plugged. Any input would be appreciated. I will be checking back as possible and update with any findings.
Gary
Gary
