I like your work. I did a wiring harness on my last hot rod (a '36 Ford) I used non insulated crimp connectors or solder and shrink sleeves everywhere I could. It make for a clean setup. Keep up the great work.
Front lighting "on"...
"Here are the front amber lights I added from Strobes-n-More. They are wired through the NC contacts of a relay to alternate with the turn signals and otherwise to stay on as running lights. I disconnected the running light filaments from the Honda stalks as they didn't do as much and I wanted the 5 watts each to spend elsewhere."
*squinting*
So, is it my imagination, or are the Honda running lights on at the same time as the fork mounted lights in this picture, or...?
Good point about the vibration and chafing.
I appreciated seeing the pics of the wiring with the panels removed. Seems there's a good bit of space to play around.
Great job, you're the master!
About the tools used, I believe I can see the solder in one of the pictures, in the ground at the left side of the bike, but can't see the crimper. Could you please post a picture of it?
In my travels, I cannot pass a stranded motorcyclist. Sometimes I am able to help, sometimes not, but I have always appreciated when someone stopped for me. (snip rest).
What does the "sweet message" mean?
It's funny, in spanish "Nacho" is an alias for "Ignacio", a spanish first name
