Agent
I'm having an issue with my front brake lever grabbing when I put on the brakes. I can pull the lever smoothly and get minimal braking up to about half way. Then, the lever sticks. With a little extra force, the lever frees up and all of a sudden we have maximum braking. It causes a lot of nose dive at higher speeds and is downright unsettling at low speeds. I'm concerned that I'll wind up with some front wheel lock up and turn a hard braking situation into a wreck.
Has anyone else had any issues with this? Any suggestions about what to do?
Can I spray the lever with something? White Lithium, WD-40, chain lube?
I'm open to suggestions. Thanks.
