anglachel
So I'm building my wish list for the motorcycle, cause the deal I had with my wife means I get a budget for the motorcycle for non-safety related items (i.e. windscreens, seats, lights, bars, luggage, etc.) starting Jan. 1.
It's far too small of a budget, and my wish list is far too large... but in time I'll get there.
BUT in looking at my dreams, one of the earlier piece that I would like is a mount for my phone so I can use the GPS navigation (and a bluetooth headset to I can hear it) while on the bike.
A mount for the phone means a port to plug in the phone. There are many out there I'm looking at something like this right now:
Amazon.com: Motorcycle 12V Cigarette Lighter USB Power Integration Outlet Socket splitter: Car Electronics
Now I've wired up aux lights on just about every car I've owned, hooked up radios, added aux ports for radar detectors in the dash, and spent the better part of 2 years attending classes at college for electrical engineering. I understand how to connect wires, use heat shrink tubing, diodes, capacitors, resistance, impedance, etc. So the basics are well covered here, but what I need is the fuse box.
I know alot of people use the honda wiring harness for a starting point, but looking at my dreams, and looking at the number of connections on the honda harness, I think I'm going to want something more flexible in the long run.
I considered a fuzeblocks and I'm still not entirely turned off on the idea, but the implimentation is a bit lacking. Namely 10 amps max per circuit. Now I don't plan to install anything with massively high draw, but I went out and looked at the draw on a full set of heated gerbing gear (jacket, pants, gloves, socks) just to get what my high end draw would be (seems like heated gear would be some of the highest draw I would put on the bike) and I came out with a need for a 15 amp fuse...
So with my dreams of an aux port on the handlebars for my phone, and an aux port in the frunk, lights, potentially heated gear, and who knows what other dreams may come up (Aux/upgraded horn, additional lights, passenger heated gear?) I want something that can handle more than just 10 amps per circuit, at least for a few circuits, even though most of the time all of the circuits wouldn't be on full blast at the same time.
So, I'm looking at options for a fuse block/box, something with switched circuits (relay on board) I'm not terribly worried about unswitched circuits (I can only think of one thing I'd put unswitched and that would be on a delay-off timer so as to not risk draining the battery, and if need be I can wire that through an inline fuse). Probably half dozen circuits, and something that will give me a fairly clean install (because I could just do inline fuses and build a rats nest of them in the battery compartment, but that just sounds like a nightmare to maintain, and more connections just leads to more problems.)
Anyone have a fuse box, that meets these requirements? Or any suggestions for a setup that might?
