lue42
This turned out to be a pretty big hassle... but I think it turned out great in the end.
Problems:
Workarounds/solutions:
This is one of those cases where I ask "what could I have done different?". Besides buying a $200 set of Kuryakyn pegs, I can't think of anything that would have made things better. That is what happens when you order online cheap stuff and are dealing with a non-standard bar size (most of these mounts are made for 1 1/4", etc - not 1")
Parts list:
Footpegs:
Lesoleil Pair CNC Black Rear Front Foot Pegs Mail Mount Aluminum for Harley Touring Sportster Softail Dyna Low Rider-in Foot Rests from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
Mounts:
PAZOMA Black Motorcycle Replacement Longhorn Offset Highway Foot Peg Mounts with 1" Magnum Clamp for Harley Bobber Chopper ATV-in Foot Rests from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
Problems:
- The mounts showed up Chrome
- The footpegs were glossy black (I knew that)
- The footpegs didn't fit into the mounts well - loose and needed drilling out
- The Givi bars were to skinny for these mounts
- No matter how hard I tightened it up, the clamp would not stop sliding
- A friend sandblasted them for me and I painted them with flat paint. Also, due to the error, the seller refunded 1/2 the price.
- For the bar size, I put a thin steel shim in to increase the bar width and added a stainless washer
- Due to the looseness, and the direction I mounted them, the pegs are put into the mount in a way (90 degrees, backwards) that they can't retract, which is ok as they don't stick out far
- I mounted the arm in such a way that it butts up against the frame and holds everything in place and stops any sliding. They don't stick out very far past the bars (maybe 3") but enough to get my boot on them and stretch out for a bit
Parts list:
Footpegs:
Mounts:
