D
Deleted member 5383
A snatchy throttle may not have anything to do with {snip}
What I was saying is that the G2 product has nothing to do with anything but mechanical change in the rate the throttle cables get pulled/pushed.
Yes, OK. Sorry.What I was saying is that the G2 product has nothing to do with anything but mechanical change in the rate the throttle cables get pulled/pushed.
Yeah, I'm not seeing the transitions on a stock mapping as a problem on the NC (in my area). It doesn't seem to stumble or surge. I should google for the mix ratios, but as you say, that's only part of the story, especially down low.A snatchy throttle may not have anything to do with air/fuel ratio but it has everything to do with how the fueling is right off the bottom, right off idle. I've had early or first gen fuel injected bikes that had very digital responses as the injectors go from wet to dry and vice versa or they surged at low rpms when the FI was going from closed loop to open loop. Compared to these behaviors the NC is very smooth despite being fueled as lean as possible.
Yep. Getting the feel for letting off just requires a bit of finesse, that also interacts with engine braking. Smooth non-abrupt changes establish a flow...To the OP I suggest saddle time and a loose hand and wrist will do wonders as right wrist to brain software is finessed and optimized.
Too bad stock tubes have cable channels that are concentric and linear.A G2 can shorten that time.
There's nothing to adjust at the throttle body.
d.
