Airfiddler
- Joined
- Jul 26, 2019
- Messages
- 8
- Reaction score
- 4
- Points
- 3
- Location
- British Columbia, Canada
When I sold my VFR, I found I really missed the air temperature readout on the dash. This Koso unit is available on ALIEXPRESS for not much money.
I hooked up the power wire to a switched fuse in the fuse box, and the ground to one of the screws that hold the Frunk in place. I had to drill a small hole
to hide the wires and route them to the fusebox. Use a multimeter to ensure you have a good ground connection. The unit comes on only when the ignition key is on, to avoid battery drain.
I think the unit looks pretty good, and is weatherproof, besides being protected by its location. The voltmeter is a nice addition, and is very accurate. Easy to read in daylight.
The air temp gauge seems reasonably accurate (+/- 1.5 degrees or so ). I don't believe there is a setting to change from Celsius to Fahrenheit, if that scale is what you are
familiar with. There are likely some available that read in both units. the blue cover on the bottom of the unit is a USB socket (left click on the photo to enlarge) This is a fun, easy to do mod.
