Naked_Duc
Although Honda calls for spark plug replacement at 32,000 miles, NGK says on their Web site that those original iridium plugs should be good for something like 60,000 to 70,000 miles.
That's pretty incredible!
I took a day off from riding, due to weather. Got back on the bike today and everything is fine. It's as if nothing had happened.
Half way home on Wednesday, the power was back to normal with some occasional "hiccups". After I got off an freeway interchange, I opened it up a bit with hard acceleration and rev'ed it up to 5500RMP. That seemed to do the trick in clearing everything up. It was 100% normal after that.
Now I am pretty convinced all these was caused by 1) almost worn spark plugs and compounded by 2) very low gas tank where the fuel pump picked up some crud (somehow). The dirty gas resulted in bad fuel mixture which wasn't combusted in one of the cylinder with the worn spark plug. Once I put in more gas, the fuel injector started to clear itself up after about 10 mile or so. By the time I got home, 25 miles or so, the injector was back to normal. Thoughts? It's either that or the motorcycle god is trying to tell me something. Or the infamous electrical gremlin?
Regardless, I am replacing the spark plugs. I will post pictures of the said plugs.
Cheers!
My 2012 is almost at 50,000 I'm still on the original plugs. I just got the cheap replacement NGK 3764 I'm installing them next weekend with allot of other maintenance workAlthough Honda calls for spark plug replacement at 32,000 miles, NGK says on their Web site that those original iridium plugs should be good for something like 60,000 to 70,000 miles.
it has been discussed there is possibly a difference between the plugs made for a car and those made for a motorcycle. I got my replacement plugs from Napa for$12 for 2 and that was for the iridium ones so it's cheap enough you could do them on schedule, but personally after hearing those cheaper ones work just fine I wouldn't pay the $45 the dealership wants per plugLikewise. I have no intention of changing mine before 50,000 miles. As showkey said, spark plugs in cars and truck routinely go 100,000+ miles.
Be careful comparing spark plug life to the lifespan of automotive plugs. My Honda pickup engine turns ~2,000 rpm at 70mph. My Honda NC700X turns nearly twice that fast, so even if the plugs were the same item, I wouldn't expect the bike's to run more than about half as long as the pickup's. That would be approx the same number of firing events.
Agree^^^^^^^ but...........also note that automotive replacing at 105,000 is a maintenance interval, the plugs do not necessarily go bad at 106,000. The modern auto has sophisticated misfire detection and the slightest fire throughs a check engine light. During EPA durability testing no routine parts are changed unless specifically defined in the maintenance book.
As far as the OP's problem..........I would doubt the plugs are the root cause.
modern cars usually use the plugs not only as a spark producing mechanism but also as a sensor by providing a bias voltage (80V?) and checking the conductivity that is affected by the presence of combustion related charged particles to check (and adjust) for pre-ignition knocking or for misfire
from what I have read around, this technology has not yet been employed in motorcycles while it is been decades since it first appeared on cars - maybe the less restricted smog regulations and the higher state of tune and narrower envelope of motorcycle engine output requirements put less pressure on manufacturers until now
from what I know, the NC has no such plug sensing in place
