BoysLikeChix
@halfSpinDoctor I swapped my signal bulbs for LEDs and I bought the same flasher from customLed as mentioned by you. Everything works fine except compared to the original flasher by Honda, my hazard light will not continue to flash when the ignition is switched off. Did you encounter the same issue?I also installed the ELFR-1-H and it works great. An electronic flasher relay should always flash at the same speed; i.e. the rate of flash is not dependent on the resistive load connected to the circuit.
You can get the CustomLED flashers on eBay from the seller custom_led_llc:
4-Pin Honda LED Flasher Relay ELFR-1-H *FAST BLINKER FIX* OEM Connector | eBay
Find many great new & used options and get the best deals for 4-Pin Honda LED Flasher Relay ELFR-1-H *FAST BLINKER FIX* OEM Connector at the best online prices at eBay! Free shipping for many products!www.ebay.com
