Albert76
Hi everybody
I have a 2023 NC750X with no accesories at all.
I already ordered some basic products from Aliexpress such as radiator protection, extended mudguards, handlebar riser, etc.
I´m thinking of adding some OEM accesories, for example, heated grips, USB and fog lights but also have to connect the relay of my GPS so that it turns on with the key switch.
Is it possible to install all this with the included installation kits or do I need to add something special to be able to connect everything without having warranty problems? Specially with the GPS (positive and negative from battery but need a "key line" to feed the relay).
OEM codes are (apparently):
08T70-MKW-D00 heated grips kit
08E73-MKW-D00 USB-C kit
08ESY-MKW-FL21 Fog lights full kit (08V73-MKS-E00 lighs + 08V70-MKW-D00 installation kit)
Does all this include what is necessary to connect it at the same time or should I consider a splitter? And to add the GPS?
If anyone has any photos of this same work done or recommendations, I would appreciate it.
Albert
Albert
