StratTuner
there was nothing wrong with your text...
I don't know what voltage the gps takes... the sae connector I have turns that into whatever standard USB puts out, and I plug the gps right into that.
I suppose what I'm looking for is a black wire (ground) and a red wire (hot) to connect the two leads from the SAE. Ideally, that circuit would be OFF when the key was turned off...
and that's about as much as I understand about wriring....
I suppose I could connect the "hot" wire to the wire that run's the headlight...since the headlight is ON only when the key is on.... I just don't know how to get to that wire without screwing up my headlight.
until then... I just have to be careful... and remember to unplug the gps from the SAE connector every time I stop.
