Tallychuckles
I have a 2023 NC 750X DCT and just installed new R-Gaza crash bars. I wanted to share me experience
The left side (traditional clutch side) went on perfect. About 10-15 minutes. The right side (throttle side) was a bit more challenging. The bottom bolt hole was about 1/32” off so I had to drill it out. Also the top “U” clamp that goes around the frame was slightly touching a part of the motor. So I used me bench grinder to take it down some. Finally there are a few more bolts that hold the horn and antifreeze coolant overflow container that need to be removed. This side (right) took me about 30-45 minutes. The final install in very nice (about and hour) and I like the look and finish. Also enclosed a few pics. One showing the side clearance with a level (never saw that before).
Final comments:
-Over all 5/5.
-Install4/5.
-I have a center stand that really helped the process
Hope that helps. Ride safe.
Final comments:
-Over all 5/5.
-Install4/5.
