Spaceteach
Just thought I'd post a heads up about an issue I ran into while installing Race Tech fork springs.
Yesterday I installed the Race Tech Gold Valve Emulators and springs in my forks. Overall the installation went well. Removal of brake caliper, wheel and fork tubes was easier than I thought it would be. Drilling 4 new holes and enlarging two existing ones in the damping rods was tedious, but not difficult and so was cutting the spring spacers to the correct length (my tubing cutter really sucks). Went to re-assemble the forks and discovered that the washers that came with the springs were too large to fit in the fork tubes. The Race Tech instructions basically tell you the the world will come to an end unless you put one washer between the top of the spring and the bottom of the spacer and another washer between the top of the spacer and the bottom of the fork cap. When I tried to drop the washer into the fork tube it wouldn't clear the threads at the top of the tube. I then compared them to the Honda washers I had removed and sure enough they were a couple millimeters larger. I couldn't just use the Honda washers because they only use one per fork tube while the Race Tech install calls for two. Luckily I found an old sanding drum mandrel that was the same size as the internal diameter of the washers. Put the washers on the mandrel, chucked them up in the drill press and held a file on each side of the washers to file them down. Had to go really slow to avoid melting the rubber on the mandrel I was using but eventually I got them small enough to fit.
After I finally got the washers in, the rest of the installation went smoothly.
As a heads up, one thing I noticed after I got the washers into the fork tube was the tube seemed wider below the threads. I think if I had just filed a flat on opposing sides of the washers so they would clear the threads they may have fit inside the tube. That trick wouldn't work on the upper washers that go under the fork cap since they have to go in straight, but the Honda washers could have been used for that location.
I don't know if all the fork springs from Race Tech come with those washers or I just got a kit with oversize washers, but I thought I'd post this just in case other forum members run into the same problem.
I've only had a chance to take a short ride today, but initial impression is the Race Tech stuff is a Major improvement
Bob
Bob
