draco_1967
Definitely not humidity. I'm in the desert and never use a pressure washer or any chemicals when washing the wheelsMaybe something in the chemical make up of the tire or living in a high humidity area?
When you remove the tire from the rim you'll find some brownish/red gritty clay or casting sand clinging to the alloy wheel (where the tire bead seats) that was not removed prior to mounting the tire.
Lou,It's really just kind of a translucent white, from the lithium grease in this Bel-Ray chain spray:
Lou,
Thanks for posting your chain lube.
I'll be buying some. I used to use the Dupont Teflon Chain Lube until
they changed the manufacturer and the formula.
PCG
