LanceK
I replaced my fork seals a while back, and yet again, the one that was leaking is leaking again. The right side fork (brake side) was leaking in the past, multiple tries at cleaning it, no luck so I swapped both seals. Now it is leaking again. I didn’t find any issues with the fork when I swapped the seals, so I don’t think that is an issue. Should I just swap it again, or is there something else that I need to check while doing it? Any brand of seals I should avoid?
