KGround
- Joined
- Apr 5, 2013
- Messages
- 34
- Reaction score
- 0
- Points
- 0
- Location
- Tampa, FL Waterflow, NM
Is there some way to remove them so they can be reused, or are they intended to be for one time use only ?
And while we are on the subject, even if they are one time what is the best way to get them off without damaging the bodywork?
I guess they probably saved maybe as much as $100 per machine when you include labor by using these cheap POS instead of real screws, and maybe they are less likely to rust in place and be hard to remove like the plated steel screws they would have used instead, since stainless hardware would have cost another few dollars. I admit it, one consideration in my purchase of this machine was its relatively low cost, but on the other hand I don't mind paying a little more where it makes for longer life or easier servicablity. And I'll bet they use these plastic fasteners on the more expensive models as well...
