2021 Kawasaki Versys-X 650 [Model Overview]
2021 Kawasaki Versys-X 650: The Quintessential Mid-Sized Adventure Tourer​
The 2021 Versys 650 ABS is Kawasaki Motorcycle’s middleweight adventure tourer, now standardized as a global model instead of being just for the US and Japanese markets. Using a 649cc liquid-cooled DOHC parallel-twin based on the engine from the Ninja 650, the Versys 650 produces 68 HP and 47 lbs-ft of torque.
Standard equipment includes ABS, semi-adjustable suspension, and dual throttle valves for optimal fuel efficiency. As well, a GPS mounting bracket is also now standard.
In Canada, the only 2021 model available is the higher spec Versys 650 ABS LT model, which is also available in the US. The only major changes over the standard model is the inclusion of handguards for wind protection, and that the Kawasaki Hard Luggage System is included with built-in Kawasaki Quick Release mounting points
The 2021 Kawasaki Versys 650 ABS starts at $8,399 USD, and the Versys 650 ABS LT starts at $9,299 USD / $10,499 CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2021 Kawasaki Versys-X 650 in one place.
  • Price: $8,399 USD / $10,499 CAD
    • Capable of both long and short distance touring
    • Economy riding indicator
    • Multiple accessories from luggage to engine guards available from Kawasaki directly
Main Specs​
  • Engine Type: 649cc 4-stroke, 2-cylinder, DOHC, liquid-cooled, parallel twin
  • Horsepower: 68 HP
  • Torque: 47 lb-ft
  • Wet Weight: 476 lbs (216 kg)
  • Seat Height: 33.1 inches (840 mm)
Competitors​
2021 Kawasaki Versys-X 650 Specifications​
Engine649cc 4-stroke, 2-cylinder, DOHC, liquid-cooled, parallel twin
Power68 hp
Bore x Stroke83.0 x 60.0mm
Compression Ratio
10.8:1
Fuel SystemDFI® with 38mm Keihin throttle bodies (2)
Lubrication
Clutch
Transmission6-speed with positive neutral finder
Final DriveSealed chain
Suspension Front41mm hydraulic telescopic fork with stepless adjustable rebound and preload/5.9 in
Suspension RearSingle offset laydown shock with remote adjustable spring preload/5.7 in
Brakes FrontDual 300mm petal-style discs with 2-piston calipers, ABS
Brakes Rear
Single 250mm petal-style disc with single-piston caliper, ABS
Tires Front120/70 ZR-17
Tires Rear160/60 ZR-17
Fuel Tank Capacity5.5 gal
Color
Metallic Moondust Gray/Metallic Spark Black
IgnitionTCBI with electronic advance
HeadlightLED
Overall Length 85.2 in
Overall Width33.1 in
Overall Height55.1 in/57.1 in (windshield down/up)
Wheelbase55.7 in
Ground Clearance6.7 in
Seat Height33.1 in
Curb Weight476.3 lb.
Warranty12 Month Limited Warranty
Kawasaki Protection Plus12 / 24 / 36 / 48 months
2021 Kawasaki Versys-X 650 Features​
Dual Throttle Valves​
Economical Riding Indicator​
ABS (Anti-lock Brake System)​
2021 Kawasaki Versys-X 650 Photos​
2021 Kawasaki Versys-X 650 Videos​
N/A
Kawasaki Official Websites​
The post 2021 Kawasaki Versys-X 650 [Model Overview] appeared first on webBikeWorld.
