2023 Kawasaki Ninja ZX-4RR Is A Track-Ready Supersport Beast
The 2023 Kawasaki Ninja ZX-4RR is one of a few special editions in Kawasaki’s 2023 lineup. The ZX-4RR is a track-ready supersport bike that builds on Kawasaki’s rich motorcycle racing heritage and is designed to deliver an exhilarating experience on both the track and the streets. The Ninja ZX-4RR is powered by a 399cc engine, which is equipped with a six-speed transmission and an assist and slipper clutch. This engine delivers an impressive power-to-weight ratio, providing a thrilling ride for experienced and novice riders alike.
Kawasaki’s advanced electronics package sets the Ninja ZX-4RR apart from the other Japanese motorcycle manufacturers. The Kawasaki Quick Shifter (KQS) allows for seamless upshifts and downshifts without the need for a clutch. Additionally, the KTRC (Kawasaki Traction Control) offers three levels of intervention, allowing riders to fine-tune the system to match their skill level and riding conditions. The bike’s lightweight chassis is designed to provide excellent handling and stability and features a steel trellis frame that offers a great balance of rigidity and flexibility. The Showa suspension components, including the SFF-BP (Separate Function Fork – Big Piston) front fork and a horizontal back-link shock allow for precise damping adjustments to suit various riding styles and conditions.
Kawasaki has also made significant strides in improving the Ninja ZX-4RR’s braking performance. The bike comes equipped with radial-mount monobloc front brake calipers to provide strong and consistent stopping power. The inclusion of ABS ensures optimal braking performance in all conditions, giving riders added confidence on the track and the streets.
The 2023 Kawasaki Ninja ZX-4RR starts at $9,699 USD/ $10,999 CAD
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Kawasaki Ninja ZX-4RR in one place.
- Price: $9,699 USD/ $10,999 CAD
- TFT Instrumentation
- Slipper Clutch
- Quick Shifter
- ABS
- Engine: 399cc 4-stroke, In-Line Four, OHC, 16-valve, liquid-cooled
- Power: 75 horsepower (estimated)
- Torque: 26.5 lb-ft
- Weight: 414.5 lbs (188 kgs)
- Seat Height: 31.5 inches (800 mm)
2023 Kawasaki Ninja ZX-4RR Specifications
Engine | 399cc, 4-stroke, In-Line Four, OHC, 16-valve, liquid-cooled |
Power | 75 horsepower (estimated) |
Bore x Stroke | 57.0 x 39.1 mm |
Compression Ratio | 12.3:1 |
Fuel System | DFI® w/ 34mm throttle valves (4) |
Lubrication | |
Clutch | |
Transmission | 6-speed, manual, return shift |
Final Drive | Chain |
Suspension Front | 37mm inverted fork with SFF-BP internals and spring preload adjustability/4.7 in |
Suspension Rear | Horizontal Back-link, BFRC lite gas charged shock w/ piggyback reservoir, adjustable compression, rebound and spring preload/4.9 in. |
Brakes Front | Dual 290mm discs, ABS |
Brakes Rear | Single 220mm disc, ABS |
Tires Front | 120/70 – 17 |
Tires Rear | 160/60 – 17 |
Fuel Tank Capacity | 4.0 gal. |
Color | Lime Green/Ebony |
Ignition | Digital |
Headlight | LED |
Tail Light | LED |
Overall Length | 78.4 in. |
Overall Width | 30.1 in |
Overall Height | 43.7 in |
Wheelbase | 1,380 mm (54.3 in) |
Ground Clearance | 135 mm (5.3 in) |
Seat Height | 800 mm (31.5 in) |
Curb Weight | 414.5 lb |
Warranty | 12 Month Limited Warranty |
Kawasaki Protection Plus | 12 / 24 / 36 / 48 months |
2023 Kawasaki Ninja ZX-4RR Features
Assist & Slipper Clutch
Economical Riding Indicator
Electronic Throttle Valves
Kawasaki’s fully electronic throttle actuation system enables the ECU to control the volume of both the fuel (via fuel injectors) and the air (via throttle valves) delivered to the engine. Ideal fuel injection and throttle valve position results in smooth, natural engine response and the ideal engine output. The system also makes a significant contribution to reduced emissions.Electronic throttle valves also enable more precise control of electronic engine management systems like S-KTRC and KTRC, and allow the implementation of electronic systems like KLCM, Kawasaki Engine Brake Control, and Electronic Cruise Control.
KTRC, Kawasaki’s advanced traction control system provides both enhanced sport riding performance and the peace of mind to negotiate slippery surfaces with confidence. Multiple rider-selectable modes (the number of modes varies by model) offer progressively greater levels of intrusion to suit the riding situation and rider preference.Less intrusive modes maintain optimum traction during cornering. Designed with sport riding in mind, they facilitate acceleration out of corners by maximizing forward drive from the rear wheel. And because Kawasaki’s sophisticated software bases its dynamic analysis on the chassis’ orientation relative to the track surface (rather than relative to a horizontal plane), it is able to take into account corner camber, gradient, etc., and adapt accordingly.
KQS (Kawasaki Quick Shifter)
Designed to help riders maximize their acceleration on the track by enabling clutchless upshifts with the throttle fully open, KQS detects that the shift lever has been actuated and sends a signal to the ECU to cut ignition so that the next gear can be engaged without having to use the clutch. On models that offer clutchless downshifts, during deceleration the system automatically controls engine speed so that the next lower gear can be selected without operating the clutch.Power Modes
Models equipped with multiple Power Modes offer riders an easily selectable choice of engine power delivery to suit riding conditions or preference. In addition to Full Power mode, one (Low) or two (Middle, Low) alternate mode(s) in which maximum power is limited and throttle response is milder are provided.Smartphone Connectivity
Clever technology enables riders to connect to their motorcycle wirelessly. Using the smartphone application “RIDEOLOGY THE APP,” a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Vehicle information (such as the odometer, fuel gauge, maintenance schedule, etc) can be viewed on the smartphone. Riding logs (varies by model, but may include GPS route, gear position, rpm, and other information) can be viewed on the smartphone. When connected, telephone (call, mail) notices are displayed on the instrument panel. Riders can also make changes to their motorcycle’s instrument display settings (preferred units, clock and date setting, etc) via the smartphone. And on certain models, it is even possible to check and adjust vehicle settings (such as Rider Mode, electronic rider support features, and payload settings) using the smartphone.ABS (Anti-lock Brake System)
Kawasaki ABS systems use front and rear wheel sensors to constantly monitor wheel speed. Should information from either of the sensors indicate that wheel lock has occurred, the ABS ECU directs the pump in the ABS unit to modulate brake fluid pressure (releasing and reapplying pressure so that traction can be regained) until normal operation resumes. ABS offers rider reassurance that contributes to greater riding enjoyment.HORIZONTAL BACK-LINK REAR SUSPENSION
Compared to the Kawasaki traditional Uni-Trak rear suspension, which mounts the shock unit vertically, with Horizontal Back-link Rear Suspension, the shock unit is almost horizontal. The original Kawasaki suspension arrangement locates the shock unit very close to the bike’s center of gravity, greatly contributing to mass centralization. And because there is no linkage or shock unit protruding beneath the swingarm, this frees up space for a larger exhaust pre-chamber (an exhaust expansion chamber situated just upstream of the silencer). With a larger pre-chamber, silencer volume can be reduced, and heavy exhaust components can be concentrated closer to the center of the bike, further contributing to mass centralization. The result is greatly improved handling.A secondary benefit is that the shock unit is placed far away from exhaust heat. Because it is more difficult for heat from the exhaust system to adversely affect suspension oil and gas pressure, suspension performance is more consistent.
2023 Kawasaki Ninja ZX-4RR Photos
2023 Kawasaki Ninja ZX-4RR Videos
2023 Kawasaki Ninja ZX-4RR review by Full Throttle:
2023 Kawasaki Ninja ZX-4RR Review by TechnoLogic:
Kawasaki Official Websites
The post 2023 Kawasaki Ninja ZX-4RR[Specs, Features, Photos] appeared first on webBikeWorld.
