jburner
How about breaking beads? Any tricks to that?
I've used this fancy contraption for my last two tire changes. The Winbag elevates the tire/wheel so that the vice pinches just the tire. The wood backing makes it so just the forward facing side of the tire's bead is broken. Then I go around 3 - 4 times per side to break the bead. The nice thing about this method is there little risk of bending the edges of the wheel (assuming you have it elevated right). The down side of this approach that you have to lift the heavy wheel/tire kinda high and balance it on a small surface.How about breaking beads? Any tricks to that?
I use an older version of this Harbor Freight changer. I keep a pallet in the garage that I bolt it to when I want to do a change. I have some carpet that I put on it to protect the rims. Some rubber lube is very helpful for breaking the bead.How about breaking beads? Any tricks to that?
I use a bead breaker tool from Harbor Freight. Easily breaks beads on light truck, car, trailer, small tractor, and motorcycle wheels.How about breaking beads? Any tricks to that?
That is amazing chain life! I do believe stiff links end the life of way, way more chains than hitting the length limit.Replaced my chain today.
40,000 miles. It was getting some stiff links. 4000 miles ago, the length measurement was still good.
This job is far easier and with accurate oil level fill if you remove the wheel and fender, and remove the forks from the triple clamps. If you just need to flush and replace the oil (most common service)., there is no need to separate the upper and lower fork tubes. On my 2012 NCX, other than the front fender, I don't need to remove any plastics to take the forks off.How difficult is lower leg service for these forks?
I have had the NC forks out several times for maintenance or upgrades and rebuilt other motorcycle forks as well. With the NC I remove the fork assembly from the clamps and separate the individual leg from the assembly for draining and specific disassembly as required for the task.How difficult is lower leg service for these forks? Compared to everything else people seem to be doing here, it seems relatively easy. I can imagine it would take a bit of work to remove all the plastic before you can release the stanchions from the crowns, but if you leave the stanchions in place and just release the fork lowers from the stanchions it should be easy enough, isn't it. Still learning so correct me if I'm wrong but isn't it just a matter of
Feel free to set me straight here. And of course you will need to remove the stanchions from the crowns (hence remove all the fairings) for a complete fork overhaul.
- Put the bike on the center stand (and maybe put a crate or something under the engine so that it really won't tip forwards).
- Remove the front wheel.
- Put a bucket under the fork.
- Remove the bolts under the fork lowers and drain the lubrication oil.
- Remove the bucket.
- Slide the fork lowers from the stanchions.
- Clean the whole lot and replace the fork seals when needed (and maybe the bushings but I can imagine that might take more specialist tools to get it right).
- Put the lowers back on.
- Inject lubrication oil up the bolt hole, slide the lowers the last bit up so that the push rods close off the hole and put the bolts back on.
- Put front wheel back in.
- Remove the crate.
Mine was doing this last summer. Also used the same tool, got about 12 grains of sand out and no more weeping.The right fork leg recently started weeping but not really leaking oil. Ever so little wet ring marking suspension travel. 100 miles of riding would leave a dirty ring around the fork leg marking the deepest compression of the suspension. I took a Seal Mate tool and cleaned out the seal area yesterday and rode a bit over 100 miles this morning and happily no "high water" mark on the fork leg. Hopefully I won't have to replace the seals for a while yet. 33,400 miles currently.
