duk2n
Some oil filter manufacturers weld a head bolt to the housing, so it's much more easy to aply the right torque:
I always try to get filters like this
HTH
HTH
However, they are available. I have one with a 3/8" socket adapter on the bottom.
While this would work in an emergency, it is not technically correct. The oil filter has an installation torque specification of 26 N-m (19 ft.-lb.) with oiled threads. I would choose to do it correctly unless I was on the road and could not do so. The oil drain bolt also has a specified torque (30 N-m or 22 ft.-lb.) and if you are right there with the right tools you can do both correctly. Aluminum threads don't give much warning when they are about to give, and I would reiterate my warning that most people over-tighten rather than under-tighten them when done by feel. I try very hard not to touch a motorcycle for repair without a torque wrench. Even if no spec is given, there is a general spec by size of bolt. Remember that the general spec is for the size of the bolt, not the wrench that fits it. I have heard of someone stripping a bolt because the bolt took a 12mm wrench and they went to the table for the torque for a 12mm fastener. It turned out to be an 8mm bolt.
The Mobil1 contains friction modifiers which are not allowed by the JASO MA specification. Mobil1 does have motorcycle specific formulations. Some people buy the car oil thinking that the motorcycle oil is just a marketing gimmick with a higher price. Not the case here.
The MA standard does not address ZDDP levels. All JASO T 903 compliant oils, of which the MA and MB standards are sub-sets, have a phosphorus level between 800 - 1,200 ppm. ZDDP is zinc dialkyldithiophosphate, and is the vehicle for providing phosphorus to the oil. It serves the purposes that you describe and has been limited lately by the EPA because phosphorus can poison the catalyst in catalytic converters if the engine is worn and has oil blow-by into the combustion chambers. Diesel and motorcycle oils have been exempted from this because they (in the past) did not have cat converters. You can probably expect a gradual lessening of the maximum allowable ZDDP as time goes on. By the way, the Mobil1 10W-30 "car oil", while not meeting the MA requirement for friction modifiers, would meet the JASO T 903 requirement for ZDDP levels.
Further to this, the MA standard is broken into two sub-categories, MA1 and MA2. You may think that MA2 is a later standard, but it is not. MA1 is the lower (slicker) end of the MA standard for friction performance and MA2 is the upper end. Oils with more friction reduction than MA are called MB. MB and unrated oils should not be used in a motorcycle with a wet clutch. If you have concerns with a wet clutch slipping, a MA2 oil would provide greater assurance than an MA1 oil, even though both would meet the standard. An MA1 oil should provide a slight benefit in fuel mileage because of the reduced friction level so long as it doesn't slip your clutch. Honda says (by specifying an MA oil instead of a MA2 oil) that MA1 oil is acceptable.
Confusing or helpful?
The local auto parts store didn't have a filter wrench that was small enough for the NC's filter. I Improvised with
a hose clamp. I tightened the clamp around the filter. I put a socket on the end of a 3/8" extension (about 4" long).
I chose a socket that was big enough to fit over the hex head screw that you tighten/loosen the clamp with.
With the socket & extension in place on the clamp's hex screw, I used a hammer to tap the end of the extension,in a direction
to loosen the filter. It was kinda like the the worlds slowest impact wrench lol. It came off without a hitch.
I reversed the position of the clamp on the new filter to install it. I needed to loosen the clamp a couple times and reposition it, when the hex head moved out of accessibility during tightening of the filter. Btw, my improvised filter wrench allowed me to do the job without removing the plastic cover/shroud.
While I agree mostly with the post about always using a torque wrench I disagree about the need to torque the filter. I have installed countless spin-on filters by tightening 1/2 to 3/4 turn after the oiled o-ring contacts the engine. This spans close to or more than a million miles of DIY service on my 2 and 4 wheel Hondas.
I think Lee is a big fan of his torquey wrench...
I always thought that there is a kind of reverse-pressure when the engine is warm and this will "seal" the drainplug and also the oil filter.
As the great philosopher Popeye says: "Ya pays ya nickel, and ya takes ya choice."
When filter installations are spec'ed with 1/2 or 3/4 turn after contact, that is what I do. "Hand-tight" is all over the map depending on where the filter is located, it's diameter, whether anything is oily, and not to mention my hand vs. Arnold Schwartzenegger's or Lady Ga-Ga's. You guys will have to excuse me (or not) for my technical bent. I am a retired chemical engineer who spent a career in the medical manufacturing industry. Everything in my "world" was done per validated SOP unless you wanted to first validate that a change was either equivalent or an improvement. I know that if I do it by the book, it will work. There may be 50 other ways to do it that will also work. Some of you have done mental retrospective validations of your methods by citing years of positive experience. My years of experience say that I do better if I follow the book - and I always have the book. If there is a reason not to follow the book, I will make a careful analysis of a different method and may then use it. I have no reason not to use the specified torque as documented unless it is a field change. In that case, I would do as you guys do and I am sure it will be fine. But it is my fallback and not my first choice.
Although anecdotal there is enough evidence from folks removing the Honda factory installed first filter and having trouble with it to the point of having to resort to holing or otherwise destroying the filter to remove it makes me think this is one area I can safely make my own judgement as to sufficient install torque. I am not that sure about your judgement however.
As we get experience with the NC700X service manual we will find that it will probably have errors. There are several in the ST1300 manual, at least one of which is a torque value of 51 ft/lbs for a caliper stopper bolt when it should be 1/3rd of that. I look forward to receiving my 700's manual which I ordered yesterday. I kept checking the Helm site to order one and it still shows unavailable but when Beemerphile ordered and got his I questioned the dealer yesterday who called Helm and was able to order me one. The Helm site is not updated yet but the manual is available.
This forum will be a good place to keep track of any that we find in the 700x service manual.
What I would like is to get my hands on this manual. I emailed Helm, but they don't reply.
Proxy volunteer wanted!
I think it is beween $75-80 USD. I don't know what post to Spain would be. I would do it for my cost if you are interested.
