That was my fault, Beemerphile, if forgot to mention. Two parts to this one tool. One side is the tire bead breaker, and the other side in the tire tool. So, one tool does it all. I would have to carry one more tire tool, because three just works so much easier than two.
At the tire changing class we got introduced to a new Motion Pro Tire Bead Breaker tool. So simple and easy to use. ... With this tool, on the road a tire change takes about 8 minutes. ...just this simple tool.
Confused. Sorry to be dense, guys, but the pix fuzzy posted was T-6 Trail Bead Buddy, OCR posted a pix of bead breaker levers, and then there was discussion about the bead breaker levers being not really necessary with tubeless tires. (And, in fact, the pix that goes with the levers shows a spoked rim which I think means a tube). I'm all for ease (demo by a pro in 8 min probably means a half hour + for me - on a good day) but for the neophyte (that's me), what is it we should be looking for?
The rain stopped just long enough to enjoy the last 50 or so miles to the campground. Got registered and paid then scouted out this perfect spot to put up the tarp, in the rain.
I didn't get a photo, but there was someone there with a tarp stretched between some trees and a hammock strung underneath. Very lightweight setup.
Were the camp sites with the fine gravel pits the sites with electrical hookups?
...Otherwise, tubeless tires are generally repaired on the wheel with the wheel on the bike. I would not burden by steed with the weight and volume of a bead breaker unless I was planning to use it. ... I do carry tubeless tire repair materials and equipment. On my tube type bikes, I always carry a bead breaker.
...As I'm sure your wife tells you at least 10 times a day, "don't overdo".
