Brake pads replacement
kaibil1
Los angeles, CA
My rear pads are gone and I want to do the job myself. I looked in the forum and I was not able to find specific part numbers or brands. Can you guys share some links if you have ordered online? I have the dct 2013 NC700X.
Thank you and sorry if the information is already here but honestly I couldn't find it.
Your best bet is to stick with the Honda pads. If you go aftermarket you may end up with some harder pads that will wear down your disk faster. Believe me, a replacement brake disk is not cheap.
Here is a lengthy thread about brakes that might be worth a read: http://nc700-forum.com/forum/garage-mechanical-help/5837-replace-brake-pads.html There are others, too. I know the search engine is a bit difficult to use successfully.
